8 Pages «<5678>
USAF 70th Anniversary build 1947-2017 Options
#121 Posted : 28 March 2017 20:14:50
Very nice and neat Carl, looks great.
Chris Cool Cool
#122 Posted : 28 March 2017 20:51:06
Beautiful work with the cockpits Carl Cool
I bet you'd be glad not to see another cockpit for a while LOL
#123 Posted : 28 March 2017 22:37:29
Great looking cockpits CarlCool
#124 Posted : 08 April 2017 17:28:41
F105-B
Thanks everyone.The final cockpit build is the F105-B.There are no 1/47 F105-B kits so I bought a Monogram F105-D and a conversion set. Since this is a very old kit the level of detail is not that great so I replaced the cockpit with an AIRES resin cockpit.The Aires cockpit is OK.The detail is a bit soft and it was a challenger to paint because of that.The headrest was also missing so I used a razor saw to chop the headrest off the kit seat and mounted it on the resin seat.
Now all of the cockpits are done it is time to start assembling the fuselages and then painting the white and silver colors.
#125 Posted : 08 April 2017 19:17:19
BigGrin Looking good CarlCool
#126 Posted : 08 April 2017 19:25:53
Nice work Carl Cool looking forward to seeing the next update.
#127 Posted : 08 April 2017 22:48:03
All looking good Carl, lovely work....Drool Drool
#128 Posted : 09 April 2017 10:08:50
Very nicely done.
Some very nice detail you have with these models and you final display will look fantastic i am sure.
#129 Posted : 09 April 2017 17:42:32
Carl great updates on both of the cockpitsDrool Drool excellent workBigGrin regards PhilCool
#130 Posted : 12 April 2017 07:02:46
This years Northern Virginia "Model Classic" event features the 70th Anniversary of the USAF
http://www.novaipms.org/MC17/MC_17_Flyer_v3a.pdf
#131 Posted : 12 April 2017 18:13:22
F4
Time to start closing up the fuselage.I glued the cockpit in place and joined the fuselage havles.Next step is to sand the seams and attach the wings.
#132 Posted : 12 April 2017 18:18:17
F84g
I also sealed up the f84g fuselage.Since this kit is prepainted sanding the seams presented a problem because the paint was sanded off.I am going to try using Bare Metal foil to cover up the areas that have been sanded and extend the foil to natural panel lines.I also sanded the paint off the tail and horizontal stabilizers since that needs to be sprayed white before applying the thunderbird decals.
It is very important with this prepainted kit to make sure you sand off the paint from any surfaces you need to glue together or the parts just wont stick together.
#133 Posted : 12 April 2017 18:22:40
Great update as this one has great appeal to me but that pre-painted finish looks difficult to work with.
Looking forward to your further updates on this one.
#134 Posted : 12 April 2017 18:49:21
Yes.I thought it would be an easy build, but the prepainting is making things harder.
#135 Posted : 01 May 2017 14:49:42
OK all 9 planes now have their cockpits fitted and fuselage closed.The next step is to sand all of the seams and clean up for priming.The Tamiya F-16s are pretty good with smart engineering to avoid any seam issues.The monogram F105 kit is predictably awful since it is an old kit and will need quite a bit of work.The kits is an F105D and I had a conversion kit to turn it into a F105B, but the resin nosepiece in the conversion is not well molded at all so I am going to stick with it as a 105D.The difference is very small anyway.
#136 Posted : 01 May 2017 15:46:55
Good to see them all together Carl Cool nice work.
#137 Posted : 31 May 2017 15:32:19
That's going to be an impressive collection of Thunderbirds through the years Cool
The USAF Thunderbirds confirmed for the 2017 Air Tattoo
http://www.airtattoo.com...irds-demonstration-team ThumpUp
#138 Posted : 31 May 2017 16:28:16
Great looking display which will lokk even more amazing when all painted up.
#139 Posted : 31 May 2017 18:57:04
BigGrin They look great all together and will look even better finishedCool
#140 Posted : 31 May 2017 22:36:58
Quite a collection Carl and all looking good....Cool Cool Look forward to seeing them progress....Cool Cool
8 Pages «<5678>
