Looking good, very neat planking. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Tomick wrote:birdaj2 wrote:]Are you planning to add the figure set to this one?
I have been trying to get hold of them but they are of stock just everyplace i have looked That's because they have not yet been released by Artesania. We will have them in the online shop when available. I will keep an eye open on the shop for them in that case. They look really nice from the pictures i have seen. Happy Modelling
Great job on the planking Alan. Top notch! Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Lovely work on the planking Alan  looking great  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thanks guys for looking in and commenting, very much appreciated....  .. If I can get the planking done the way I want then hopefully there will be little or no filler needed.... Regards Alan
Nice neat work Alan and a great guide to follow Steve
stevie_o wrote:Nice neat work Alan and a great guide to follow Steve Thanks Steve, appreciated as always.... Regards Alan
Stage 7 The planking done so far now has to be sanded smooth, filling any dents or hollows. Fortunately I haven't needed to use any filler as yet... The inside of the main deck bulwarks also require to be sanded smooth and for this task I found cutting the rounded end off of a nail file ensured I could get down to deck level without damaging the deck in the process.. The kit comes with a template showing the ribs and gun port positions. Cut the two templates out and then cut out the gun ports. Using masking tape I then attached the templates onto both sides of the hull lining up the rib markings and the bottom edge using the measurements contained in the instructions. Regards Alan Gandale attached the following image(s):
 looking great Alan ,nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks great Alan, very neat job. Regards Mark Regards Markwarren (Mark) Admin
Nice update Alan, looks great mate. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Looking good Alan “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
That is some of the neatest planking I've ever seen. Ken's the name modeling's the game.
Alan Lovely neat work on the planking. Happy Modelling
Brilliant job on the planking! Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks everyone for looking in and the very nice comments, always very much appreciated. Am now in the process of marking and cutting out of gun ports, will update as soon as its done.... Regards Alan
Hi Alan. Very neat and tidy build. Looking fantastic. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Superb planking Alan , loving this build Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Ian, Martyn, thanks for the great comments, appreciated.... Regards Alan
Moved this build on a little further. Once the templates were positioned correctly the next job was to mark out all the gun ports and then remove the templates. Happy with the marking I then moved onto actually cutting out the ports, this I did by using a 1.5mm drill, drilling holes around the inside of the port edges ensuring I left a margin of error. Using a fresh blade I then cut the ports, cutting slowly so as not to splinter any of the wood especially on the inside of the ports on the main deck.. The last job on this build session was to tidy up the port edges using fine files and emery boards. The final clean up will happen when I come to fit the port linings.... This completes stage 7. Regards Alan Gandale attached the following image(s):
Guest (15)
