20 Pages <12345>»
Karl's H.M.V Endevour.Part work's with Eaglemoss. Options
alantait
#41 Posted : 03 March 2011 21:41:40
thats what i have just received the stern section and another rib
current builds
budgie
#42 Posted : 04 March 2011 12:17:05
Bored snap issue 6 with issue 7 parts left with WH Smith to sort out
pick up both issues next week to see if theres been a mix up
BigGrin at least i don't need to try & contact customer services
#43 Posted : 04 March 2011 16:06:43
how strange,as my parts were correct,???? good luck for next week.
budgie
#44 Posted : 04 March 2011 18:30:53
Blink if everyone was in the same boat (excuse pun)i would have accepted the issue & assumed parts for issue 6 would come with issue 7 but that was not the case as i saw Karls pics with correct parts
alantait
#45 Posted : 04 March 2011 21:04:55
all the magazines in the local wh smith were the same issue six with issue 7 parts. strangeConfused
current builds
spity360
#46 Posted : 04 March 2011 21:28:41
Mine was ok mind you packaging could be better
Paul
Venice
#47 Posted : 04 March 2011 22:45:23
Hi Karl,
I'm not 100% sure but the planking on the forcastle deck should cover the ribs.
If you take another look at the what your parts should look like picture it shows the planking continues over the ribs also when placing mine back on after cutting our the rib spaces I noticed that the rib height was a lot lower than the deck.
I have since re-planked the bits I cut out.
Present Build:
H.M.S. Victory
H.M. Bark Endeavour
Photobox build album
It cant be that bad, what do you mean it's sinking
#48 Posted : 05 March 2011 15:13:38
thanks for that venice will check it out.
#49 Posted : 10 March 2011 14:25:42
issue 7 has arrived,contents all ok.btw bought some gorilla glue to trial,did a little bit of planking with it,so far NOT impressed,takes ages to dry,not as quick as aliphatic glue.
#50 Posted : 10 March 2011 14:29:36
#51 Posted : 10 March 2011 14:49:43
Hi Karl, I've used the brown Gorila glue (expanding version), where you dampen the surface first; its great for where you need to span a joint gap because it expands/fills and is also waterproof, and when dry the excess which is foam like can be cut way, but its awful to remove if you get residue where you dont want it, the shelf life once open ain't too hot either.
yorkieboy1
#52 Posted : 10 March 2011 20:55:59
I have gone through the newsagent called in last week and ordered all the parts up todate seven I believe had a cll from the newsagent to tell me i have six issues ready to pick up alot better than the subscription method I have got all the tools now so am not bothererd about the freebies looking forward to building it especially with quite a few of victory lads building it plenty of advice and encouragement happy modelling
#53 Posted : 11 March 2011 12:55:47
#54 Posted : 11 March 2011 20:10:54
Hi Karl are you enjoying the Endeavour build?
I have 5 issues, waiting for more before I start, but not sure about the quality.
Whats your view?
Cheers
MWGConfused
#55 Posted : 11 March 2011 22:05:13
hi, my opinion so far is,quality,fair,wood very prone to warps,have to keep a constant eye on it,and be ready to wieght it down after damping,I am doing a bit of kit bashing on this one,like walnut decking,and probily use different veneer to the one supplied.
#56 Posted : 11 March 2011 22:15:05
Thanks for your input Karl, I will proberley stay with it,yours is looking great!
Wilfy the Sea Dog
#57 Posted : 16 March 2011 09:28:57
Hi Karl,
Can you tell me what the latest issue you have received is?
I have gone the subscription route and received issues 2-5 wityh no probs.
So far in March the have billed my card twice total amount about £45 (equates to about 7 1/2 issues???)& not received anything yet.
Thanks
Wilfy
#58 Posted : 16 March 2011 09:41:57
issue 7 was the last one,no.8 tomorrow,this is why I cancelled my subs,I now collect from my local newsagent,did'nt like them taking my money first,and not delivering on time,yes I don't get the freebees this way but I don't get the stress either.
Wilfy the Sea Dog
#59 Posted : 16 March 2011 13:30:11
Thanks Karl.
Evevtually spoke to someone there, apparently extra is for a special issue! Special issue after just 7 normal, could get expensive & to top it off these issues arrived late & have held despatch of all the normal issues up.
Think you have right idea of going to the Newsagent.
Build looking good by the way.
Thanks again.
Wilfy
#60 Posted : 17 March 2011 16:57:22
Issue8 another piece of deck,and 1 rib.
20 Pages <12345>»
This page was generated in 0.224 seconds.
