106 Pages «<1920212223>»
Sticky Wickett
#401 Posted : 30 March 2017 18:21:17
This photo shows the other end that has to be fitted with a profiled and scalloped end piece.
Sticky Wickett
#402 Posted : 30 March 2017 18:23:09
This picture shows the start of shaping and contouring a 0.5mm plastic sheet so that it fits the saddle tank. The uncut piece i'm holding will be removed later.
Sticky Wickett
#403 Posted : 30 March 2017 18:24:29
This image shows the same piece being offered up to the saddle tank to check for fit.
Sticky Wickett
#404 Posted : 30 March 2017 18:33:20
When I was happy with the fit of the profile I held it in place and drew around the outer shape of the saddle tank onto the excess plastic sheet I was holding. I carefully cut away the excess, checked it against the saddle tanks to make sure it was correct and then marked out, with a fine permanent pen, the area to remove internally. Removing an internal section gives the impression of depth to the tank ends matching the part-works supplied brass-etched parts for the Control Room and Engine Room.
The attached image shows the profiled piece cut to size and marked out.
Sticky Wickett
#405 Posted : 30 March 2017 18:34:49
This photo shows the piece being checked for fit against the saddle tank.
Sticky Wickett
#406 Posted : 30 March 2017 18:36:05
Once happy, I proceeded to remove two internal sections. This picture shows them removed.
Sticky Wickett
#407 Posted : 30 March 2017 18:37:48
This image shows another dry fit to make sure the centre section on the profiled piece was at the correct angle; towards the centre line of the hull.
Sticky Wickett
#408 Posted : 30 March 2017 18:40:29
This photo shows the profile piece being glued to a 0.5mm plastic sheet. This backing sheet improves strength and durability and also highlights the tank ends internal shape similar to the part-works supplied pieces.
Sticky Wickett
#409 Posted : 30 March 2017 18:41:31
This photo shows the backing sheet glued in place and filed flush to the profiled piece.
Sticky Wickett
#410 Posted : 30 March 2017 18:43:10
This photo shows the completed scalloped and profiled tank end glued in place. I think it looks in keeping with the rest of the U-boat.
Sticky Wickett
#411 Posted : 30 March 2017 18:44:17
This image shows a close up of the profiled edge against the saddle tank.
Sticky Wickett
#412 Posted : 30 March 2017 18:45:18
Another close up showing the profile piece filed smooth and flush to match the saddle tank curve.
Sticky Wickett
#413 Posted : 30 March 2017 18:49:02
Time to start on the other end. LOL I followed the same procedure as before and this photo shows the profiled piece cut to shape and internals marked out.
Sticky Wickett
#414 Posted : 30 March 2017 18:50:15
Another close up showing the marking out.
Sticky Wickett
#415 Posted : 30 March 2017 18:51:26
The same piece being checked for fit to confirm it's correct.
Sticky Wickett
#416 Posted : 30 March 2017 18:53:10
This image shows the internal tank profile cut out.
Sticky Wickett
#417 Posted : 30 March 2017 18:54:15
The completed profile piece filed smooth and ready for fitting.
Sticky Wickett
#418 Posted : 30 March 2017 18:55:35
As with the previous profiled tank end, it was checked again for fit and look before attaching the backing sheet.
#419 Posted : 30 March 2017 18:56:25
Very smart.
You really do know what this should look like and your changes are really interesting to see.
Been collecting this one but have a feeling if i ever build it its going to be sadly lacking in detail.
A real great job you are doing with this one.
Sticky Wickett
#420 Posted : 30 March 2017 18:56:28
The completed profiled tank end fixed in place.
This page was generated in 1.119 seconds.
