106 Pages «<2021222324>»
Sticky Wickett
#421 Posted : 30 March 2017 19:03:48
birdaj2 wrote:
Very smart.
You really do know what this should look like and your changes are really interesting to see.
Been collecting this one but have a feeling if i ever build it its going to be sadly lacking in detail.
A real great job you are doing with this one.
Thank you Tony. I do spend an awful lot of time pondering and thinking things through before I attempt these modifications. I'm gearing up to finish the internal structures by early June then it's paint time!
Don't be put off, the part-works has some great details.
Phil W
Sticky Wickett
#422 Posted : 30 March 2017 19:04:24
This final photo shows a close up of the scalloped piece.
Sticky Wickett
#423 Posted : 30 March 2017 19:06:07
Well that's it from 'The Dockyard' for tonight.BigGrin
Thanks for looking in, have a great weekend and happy modelling.
Kind Regards,
Phil W
#424 Posted : 30 March 2017 20:40:49
Another great update PhilDrool Drool well doneBigGrin regards PhilCool
#425 Posted : 30 March 2017 22:38:12
Another superb update from you Phil, she's going to turn out to be one stunning build....Drool Drool
Sticky Wickett
#426 Posted : 31 March 2017 09:39:04
Thanks Phil. Your comments are always welcome.BigGrin
Phil W.
#427 Posted : 31 March 2017 17:32:16
All the work and attention to detail you are putting into this is really starting to show, I'm really eager to eager see the interior start comes no together BigGrin Cool
Sticky Wickett
#428 Posted : 03 April 2017 08:53:29
Thank you Alan. More updates to follow.
Phil W
Sticky Wickett
#429 Posted : 03 April 2017 08:54:19
Thanks Dave,
Adding the interior details will be fun to do.
Phil W
Sticky Wickett
#430 Posted : 05 April 2017 07:03:33
Good morning from 'The Dockyard'.
This part of my U230 u-boat log i'm building the 'panelling' that sits above the Junior Rate Mess & Galley representing the cut-away section of the top of the saddle tank. I wanted to continue this theme as there is part-works supplied photo-etched brass panelling for the Control Room and Engine Room saddle tank cut-aways.
I made the panelling from plastic sheet and strip.
The attached photo shows the base of the panelling cut to size. I used 0.25mm thick plastic sheet.
Sticky Wickett
#431 Posted : 05 April 2017 07:05:41
This photo shows the base of the panelling being checked for fit.
Sticky Wickett
#432 Posted : 05 April 2017 07:08:18
This image shows the various sizes of plastic strip I used to make up the panels; 1.0mm [wide] x 0.5mm [thick] and 2.0mm [wide] x 0.5mm [thick].
Sticky Wickett
#433 Posted : 05 April 2017 07:11:38
This photo shows the making of the panelling border using 1.0mm x 0.5mm strip. I used bulldog clips to hold it in the correct position while I ran a bead of superglue along it's edge.
Sticky Wickett
#434 Posted : 05 April 2017 07:14:48
I left the strip over-length to be cut to size after gluing. This photo shows the second border fixed in place using the same method as before.
Sticky Wickett
#435 Posted : 05 April 2017 07:16:40
In this photo the first rung of the panelling has been cut to size from 2.0mm x 0.5mm plastic strip.
Sticky Wickett
#436 Posted : 05 April 2017 07:18:00
This photo shows the rung glued in place.
Sticky Wickett
#437 Posted : 05 April 2017 07:19:49
This image shows the border strip filed flush.
Sticky Wickett
#438 Posted : 05 April 2017 07:23:41
This image shows the second rung cut to size. You can just make out the 8.5mm gaps marked out in pencil for each rung.
Sticky Wickett
#439 Posted : 05 April 2017 07:24:35
The second rung fixed in place.
Sticky Wickett
#440 Posted : 05 April 2017 07:25:40
This photo shows the completed panelling with all rungs glued in place.
Guest (18)
This page was generated in 0.409 seconds.
