4 Pages <1234>
Queen Elizabeth-class battleship HMS Barham 1/700 scale Options
#41 Posted : 31 March 2017 21:09:29
Sticky Wickett wrote:
Nice weathering so far Jase.
Phil W
#42 Posted : 31 March 2017 21:14:35
davetwin wrote:
Great job so far Jase Cool
Your poor eyes with all that tiny PE Blink
Hi Dave thanks for looking in. the railings are a bit tricky. Think the rigging may be the bigger challange at this scale Blink
#43 Posted : 05 April 2017 11:34:57
Looking great Jase. look forward to seeing your progress. Ian Cool BigGrin
#44 Posted : 22 April 2017 17:17:37
Weathering of the hull continues with the screws.
Following Tomiks helpful pic and thoughts on the screws I came up with giving them a wash in dark oak wood stainBigGrin the translucent brown gives a nice aged look and dulls down the shine of the brass.
Weathering the lower hull continues with some light grey chipping. most heavily at the bow which sees so much abrasive action at sea. I also did some chipping where I thought the ship may have rubbed against other boats docks etc.
Once dry A darker grey was also chipped, the idea in my mind is to try and show newer and older chips. The darker grey chipping was extended to the upper hull. Agin prominently at the bow but along the waterline and the hull sides generally.
With this done I was able to apply the rust effects. some of the larger chips above the waterline were given a touch of rust and some occasional rust along the hull sides. more heavy rust applied on the stern gallery with all that mesh, easy rusting points and at the bow again.
Finally several coats of rust was were applied where the anchors are rubbing up and down the hull
#45 Posted : 22 April 2017 20:48:00
Blimey, she's certainly well worn ThumpUp
#46 Posted : 22 April 2017 21:41:12
I am using Colour photos from the falklands war as a reference. The Camra flash does over exaggerate the colours a bit, I am happy with it though.
Thanks for looking Cool
Jason
#47 Posted : 06 May 2017 14:10:26
The first sub-assembly parts have now been painted and given a wash. This allows assembly of the upper works to progress. I have added some of the ships boats while access is easy. there is still more painting such as the blast bags and etch such as railings and cranes to be added on some of these assemblies, this will be done on the built up model
In a carless moment I managed to break of my main mast top, it has disappeared into a black hole, so I have had to fabricate a new one.
The final set of sub assemblies are now complete and ready for priming.
#48 Posted : 06 May 2017 21:31:47
There is some very nice etch work in such a tiny scale Blink Blink
#49 Posted : 06 May 2017 23:07:11
She's coming along nicely, etch work looks great....Cool Cool Cool
#50 Posted : 07 May 2017 11:50:03
Thanks for looking in Dave and Alan, looks like I have a good chance of getting this across the line in time LOL LOL LOL LOL Cool
#51 Posted : 08 May 2017 11:15:06
You are doing a great job on this JaseBigGrin the etch work is superb BigGrin regards PhilCool
#52 Posted : 08 May 2017 21:57:12
Thanks Phil,
many thanks for the kind words
#53 Posted : 19 May 2017 21:14:17
Ships boats tops are fitted and painted and given a wash. the funnel sub assembly has been weathered and glued in. The blast bags have been pained white and the main mast given a first coat of black and white paint along with the funnel top. pom pom platforms are also done along with the secondary armourmant.
nightwisher
#54 Posted : 19 May 2017 22:06:44
Looks fantastic, Such fine detail in this scale. Don't know how you do it.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#55 Posted : 19 May 2017 22:36:12
Nice looking model
#56 Posted : 21 May 2017 20:30:06
Thanks Chaps.
fairly sure I will be inside the deadline this year LOL LOL LOL LOL LOL
#57 Posted : 21 May 2017 22:54:51
Getting closer to the finish line Jase, coming along nicely....Cool Cool
#58 Posted : 22 May 2017 07:54:46
Coming on very nicely, looks excellent.
#59 Posted : 23 May 2017 23:38:28
The last remaining superstructure is now in place, a bit more work to do on the finish.
Anchors are in as is the stern jack pole.
The wood deck came with anchor chain, but this is massively over size for my liking, so I left on the moulded on anchor chain and used the etch chain to extend the the kit chain.
The kit comes with four aircraft, all the same, one of which can be sat on the catapult on C Turret. I have added the cradle and built up the aircraft. the idea of the aircraft being made as clear parts is cracking, but the thing feels very chunky and oversized for the model. I have chosen not to add it to the build.
I have However built one using the etch set so you can see what this would look like.
The process of installing railings and booms has now begun. I am finding my etch rolling tool very handy for the curved deck edges that need to be formed
Those of you with a keen eye may have spotted what looks like a hair on my camera lens, but you would be mistakenBigGrin LOL its actually rigging, yep thats right I am going to do some rigging on a 1:700 scale battleshipFlapper Yes I am bonkersLOL LOL
I am using this rubber thread that is0.01 of a mm thick, you can hardly see the dam stuff. you attache one end with a spot of glue and stretch it to the next point and another spot of CA at grabs instantly and trim it. looks fab I think
SOOOOOOOO close to finishing
DaDokta
#60 Posted : 24 May 2017 08:16:37
Your skills are awesome! Fantastic weathering!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
4 Pages <1234>
This page was generated in 0.362 seconds.
