Bulkheads Options
CaptnBirdseye
#1 Posted : 05 April 2017 17:07:07
Rank: Superelite
Hi all
I see with this model you actually glue the bulkheads in place as you go, unlike the Victory, which is left loose until the decks are in place. Is this a better method or just the way the kit is made?
thanks
#2 Posted : 05 April 2017 17:30:56
BigGrin Hi CaptnBirdseye the bulkheads are glued in as part of the build its just the way the kit is made as the decks are in two pieces so you can slot them in Cool . Hope this helps rgd Martyn
#3 Posted : 05 April 2017 18:29:15
Each manufacturer makes their kits differently. Follow the instructions if unsure how they go.
Chris
This page was generated in 0.650 seconds.
