Proxxon Wood Carver Options
#1 Posted : 06 April 2017 15:59:08
The woodcarver comes with a set of 3 blades as standard but I also got a set of blades and a sharpening set. Not much use to a modeler you say but it will make short work of bow and stern blocks before the sandpaper comes out saving a lot of time. Also with practice some fine work is achievable with it.
#2 Posted : 06 April 2017 17:31:46
It can also be used for shaping wood or plaster blanks prior to creating a mould for resin casting.
https://m.youtube.com/watch?v=xdgcRw6Oc90
#3 Posted : 15 April 2017 12:17:34
BigGrin I have used this a couple of times now and it makes short work of anything you task it withCool
This page was generated in 0.505 seconds.
