Evening Fellow Modellers, This will be a relatively quick build log of a Bedford HA van in 1/43 scale. Why a Bedford HA van? Back StorySuzanne works with my missus and is a friend to both of us. She is getting married at the end of May, being taken to the church in a restored MK1 Escort RS driven by her dads cousin. I don't know his name but I do know that he runs a garage in Pembrokeshire and drives around in an immaculate 'N' reg [1973] Bedford HA van. He has often bemoaned the fact that he would love to have a model of a Bedford but has been unlucky in finding one. Suzanne did a bit of research 'on the quiet' and found a suitable model. She has asked me to build it so it can be presented to him on her wedding day as a token of thanks and also a massive surprise! The Kit The kit is produced by Promod Ltd who specialise in white metal model kits. There are a few plastic components but mostly white metal. The overall quality of the parts are very good making for a very life like model when finished. I have also bought a small, solid oak plinth to mount the car onto when complete so it can take pride of place in his office or on his mantel piece. The model will be painted as per the original in white. I will make my own water slide decals for the company logo to be fitted on each side of the van. I will also make my own printed paper cut outs for the tax disc, number plates front and rear and the Bedford insignia on the front grill. I will replicate a lot of the chrome parts as seen on the original by polishing the white metal with steel/brass wool before varnishing to 'lock in the shine'. The model doesn't come with instructions, just a b/w photocopy of parts supplied. To be honest there isn't a lot to this kit so figuring out what goes where isn't too difficult. The attached photo shows the parts photocopy with the components laid out on top. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The attached photo shows the interior base. I have already spent some time cleaning up the flash and checking it for fit with the chassis. As can be seen I have already sprayed this part; matt white for the rear of the van interior and matt black for the cabin representing the carpet. Two coats for each with a coat of matt varnish to seal all areas. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
This photo shows the chassis. Again, I spent some time cleaning up this component before spraying matt black and varnishing. I masked off the exhaust pipe as it looked rather good in white metal. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Attached is a photo of the oak plinth. I have already drilled a counter-bored hole to accept an M3 cheese head bolt. I have soldered a brass nut into the white metal van interior with a hole through the chassis so that the bolt locks the van to the base. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Another picture of the oak plinth showing the M3 cheese head bolt Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
With smaller models, the exhaust pipe always gives the game away as they usually have a solid end. To remedy this I partially drilled the end out with a 0.5mm diameter drill and painted the hole with a fine, permanent marker. See attached photo for the end result. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Phil That is a real nice thought to put your modelling skills too. Never come across this brand of kit before so very interesting. Hope it all goes together well for you. Happy Modelling
Here is a close up of one of the wheels fitted to it's rubber tyre. I will polish the centre cap and leave the outer rim 'as is' before varnishing. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Here are a couple of images of the plastic bodywork. This will be painted gloss white then varnished before adding my own DIY water slide decals, painting the windscreen seal and indicators. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I'm looking at completing this van by early May, giving plenty of time before Suzanne gets married and her dads cousin is handed something he has always wanted. More posts to follow soon. Thanks for looking in! Kind Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
birdaj2 wrote:Phil
Hope it all goes together well for you. Hi Tony, Thank you. Suzanne and all of her family near and distant are car mad. She has already seen a couple of these pictures and to say she is super excited is an understatement! I can't wait to show her the finished van. It also makes for a nice 'palette cleanser' while i'm still building my U-Boat. Kind Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Phil And it really does look a smart little model and I am sure from what you have said will be very warmly received. Will be following along with interest. Happy Modelling
Well what a change from the U-boat  great surprise for your friend  i`ll quote Wallace should be cracking grommit when complete  will watch with interest  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Thanks Phil. Maybe I should put some cheese in the back of the van? Regards, Phil W Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looks like a fun little build Al and I'm sure you'll do a great job with it.....  .. Will be watching all the way... Regards Alan
Gandale wrote:Looks like a fun little build Phil and I'm sure you'll do a great job with it.....  .. Will be watching all the way... Regards Alan Cheers Alan. It should be a nice, little display piece when done. Thanks for looking in. More posts to follow soon. Kind Regards, Phil. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That's an interesting and fun looking build
davetwin wrote:That's an interesting and fun looking build Thanks Dave. I had no idea there were models of Bedford HA vans out there. A quick and fun little build that I can slot around my U-Boat log. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
My dad had one for years, we called it the HAHA van! Great looking little kit, looking forward to seeing it built.
Nemesis wrote:My dad had one for years, we called it the HAHA van! Great looking little kit, looking forward to seeing it built. Hi Nem, The HAHA van; I like that.  Thanks for looking in. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (12)
