Hong Kong Models Dornier DO 335 Zerstorer Pheil 1/32 scale Options
#1 Posted : 13 April 2017 21:22:12
This is another first for me a HK Models kit and I am impressed but first some history.
The DO-335 was the fastest piston engined aircraft in the German luftwaffe at the end of the war with a push/pull engine layout. The 'B' series was the Zerstorer or Destroyer was the heavily armed version with three 103-30mm guns two in the wings one firing through the front propellor shaft plus two MG 151 20mm mounted in the upper front cowl. Another 1st for the Anteater or Pheil as it was nicknamed was it was designed with an ejector seat for the pilot.
The kit comes in a sturdy and deeper than the norm large box comprising of 282 parts in grey plastic,some etch,nose weights,decals and instructions. The nose weights are hidden in the build the larger one is hidden inside the front engine.
Examining the parts show no flash at all and a very high degree of surface detail that shows panel lines,hatches and rivets on all the external parts plus the interior parts also have lots of wires/detail moulded into them. The wheels come already weighted and you have the choice of the clipped or extended wings.
The instructions are clear and well set out the first page showing the parts/sprue breakdown and then the colour chart. The layout is easy to follow and clear throughout and has three choices of aircraft including one in captured french roundels. The kit can be built undercarriage down/hatches open or in flight mode.
To enhance the kit I have the Big-Ed set that has etch for the interior, exterior, seatbelts and masks. Brassin muzzle brakes and metal landing gear to replace the plastic one provided in the kit. I also have two paint sets that have the correct RAL colours. The last extra is the book that has lots of pictures and information on the DO-335 including many pictures from the aircraft instruction manual.
In conclusion a very nice kit with high detail and one that can only be a joy to build.
#2 Posted : 13 April 2017 21:28:30
Nice looking kit and extras
Looking forard to seeing that build up
#3 Posted : 13 April 2017 21:40:31
You certainly pick some nice builds Andy. The parts shown, look really crisp and well detailed. I shall be watching with interest.BigGrin
#4 Posted : 13 April 2017 23:00:30
An interesting looking kit Andy.
I've never seen an HK kit myself but have read lots of positive things about them, from the pictures it looks nicely detailed.
Will be following Cool
#5 Posted : 13 April 2017 23:01:08
Another unusual kit Andy, am sure you'll build it to your usual high standards.... Look forward to seeing it come together....Cool Cool
#6 Posted : 14 April 2017 08:35:07
Thanks for looking in and your comments, its a well thought out kit the front wing joints are underneath the front section and follow the panel line under the forward wing si it looks like there is no joint there. Unlike a lot of kits that are butt jointed and you get the joint line to sort out.
#7 Posted : 14 April 2017 10:28:21
Thats a nice idea, its those little things that make the difference
J
#8 Posted : 14 April 2017 10:44:23
I have not built one of their kits yet, they do look very high quality. Looking forward to seeing this started.BigGrin
#9 Posted : 14 April 2017 13:01:59
Not yet done a HK kit myself but fancy one of there B-17's or the upcoming Lancaster. This looks a quality kitDrool and i'm sure you will make a great job of it.
#10 Posted : 14 April 2017 13:02:40
Its a very unusual looking aircraft and looks very high off the ground.
I have seen - smaller version of this one that tamiya issued but will be interested to see how this larger one builds.
When i got hold of my 1:32 mosquito it was a toss up between a hk kit ot tamiya and in a way i wish i had opted for the hk version because looking at this one you have i bet their mosquito would have been a good one as well.
Hope it all goes to plan.
#11 Posted : 14 April 2017 14:23:36
An unusual subject and with all those extras it should make for a great build.
#12 Posted : 14 April 2017 17:27:49
They are nice kits BigGrin have one in my stash will look forward to the build Andy BigGrin regards PhilCool
#13 Posted : 14 April 2017 20:49:51
BigGrin Thanks for looking in everyone and your comments, another nice point about the attachments to the sprue's are very small so minimal clean up in detached area'sCool
Guest (6)
This page was generated in 0.159 seconds.
