 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
I was under the impression (from the pictures) that we whould receive one of those hand-drill jobbies with the 'toolkit' - this turned out to be a mistake on my part. Anyone know where in SA one can get one of the hand drills (sorry I can't remember the correct term for it now) I have a Dremel with the drill stand and a chuck attachment so if I can source mirco drillbits for a reasonable price, could it be an option?
 Rank: Vice-Master  Groups: Registered
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
if its the same tool kit we get in the uk you shoud have the drill plus a drill bit drill looks like a handle with a twisted steam as for dremel a lot of modlers use them and a little tip cut the head of a pin and it will drill wood dress making ones are the best 0.8mm dia
The drill is called an Archimedes drill...I have one and had it for a number of years, damn handy drill to have too. Have you tried sourcing a drill and drill bits on google or E.Bay...shouldn't be too difficult to pick up one...hope this helps??? Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Thanks Gents! The kit supplied in SA does not have the drill, even though the earlier pictures of the kit showed one. Does one just cut a notch in the head of the dressmakers pin? I'll use the dremel, even though I suspect the hand drill will give one more control.
Joined: 24/09/2010 Posts: 15 Points: 48 Location: Broederstroom
I got the tool kit supplied and it did contain a archemedies drill. Not a very good one but one never the less.
StefanDV wrote:Thanks Gents!
I'll use the dremel, even though I suspect the hand drill will give one more control. just cut the head stright off with a pair of snips, the cutting with snips tapers the point and that cause it to drill ,eg >
Joined: 18/12/2010 Posts: 59 Points: 177 Location: Pretoria (SA)
I received my tool kit including the hand drill. It’s not the best of quality but remember the tool kit it’s for free. Albatross, build in 1982 from plans. Hms Bounty, build in 1987 from plans. Duyfken,build in 1991 from plans Oosterland, build in 1998 from plans 2010 Hms Victory kit from Deagostini
In the meantime. 2011 Building MFV 1963 fishing trawler from plan.
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
Hi StefanDV See my post on the drill supplied http://forum.model-space...aspx?g=posts&t=1971
I received the drill yesterday after ordering it on 17/2/11. Very happy with quality. Cost including air delivery $8.39 Athol
Hi, if you haven't found the bits, I know of a place.
In cape town (montague gardens to be exact) there is a hobby shop called "Clowns Hobbies". They stock artesania Latina products, including a 5 drill bit set (0.5mm, 0.75mm, 1mm, 1.5mm, 2mm I think). They are just before the Trade Centre in Koeberg Road. Hope that helps =)
Great, thanks Francois! Go you know which exact sizes do we need for this model? (some places stock decimal bits (0.5mm etc) and then one also find some strange sizes (60,80 etc))
StefanDV wrote:Great, thanks Francois!
Go you know which exact sizes do we need for this model? (some places stock decimal bits (0.5mm etc) and then one also find some strange sizes (60,80 etc)) ------------- these are number drills some times called wire guage drills some times the victory instructions refere to them you will find plenty of conversion charts on the net sizes used on the model so fer is 0.7,0.8 ,1.0and 1.5mm
Thanks Willie, So far (up to issue 16 only and still waiting for issue 14) I've only used a 0.5mm, 1mm and a snipped sewing needle. (Shown below)
Guest (8)
