 Looking good Alan, those perma-grit files are a godsend for getting nice square gunports Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Shaping up nicely “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Very neat work on your gunports. Such a difficult part of a model to get right as it needs such a delicate touch. Hope it all continues well for you. Happy Modelling
arpurchase wrote: Looking good Alan, those perma-grit files are a godsend for getting nice square gunports Thanks Andy, have to agree with you, perma-grit files to me are an essential tool in my toolbox. Wouldn't be without them.....  Regards Alan
Jase, Tony, thanks for looking in, very much appreciated.... Regards Alan
Stage 8 This stage was a short stage. All that was required to be done was to paint the dummy gun supports with 2 coats of matt black, not forgetting the sides of the ribs where they can be seen through the gun ports.. The same treatment was done on the stern section where it will be seen through the stern gallery windows.... That completes stage 8. Regards Alan Gandale attached the following image(s):
 Looking good Alan Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Nice work Alan. Looking fab. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Great job Alan, she is looking very neat.
Martyn, Chris, Graeme, thanks for looking in and your comments... appreciated.... Regards Alan
Nice work Alan Regards Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Nice work Alan Regards Mark Thanks for looking in Mark, appreciated.... Regards Alan
Very neat bit of work. Its all taking shape very nicely now. Happy Modelling
 Looking good Alan Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Tony, Andy, thanks for looking in and commenting... appreciated... Regards Alan
Lovely work there Alan. Regards, Phil W Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks Phil, appreciated.... Regards Alan
Stage 9 Start this stage by taking the stern transom, place it on a piece of paper and draw round the top openings of the bannisters to create a template. Keep the template safe for future use. The bottom of the transom section has a small curve to it, I used steam from a kettle to gently bend to match the shape of the stern. Once happy the stern transom was glued into position and left to dry before continuing... Turned the ship upside down to start planking the aftercastle, care should be taken not to break the stern transom during this planking process. Using the measurements supplied in the instructions, shape the first plank to neatly fit at the base of the stern transom, once happy glue in place. Once dry add two more planks ensuring you glue the edges of the planks together. The last plank fitted to this area must finish at the lower edge of the stern so you need to trim and sand the final plank to fit. This completes stage 9. Regards Alan Gandale attached the following image(s):
Its all going together very nicely Alan. Happy Modelling
Nice work Alan. She's looking great. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Guest (11)
