106 Pages «<2425262728>»
Sticky Wickett
#501 Posted : 20 April 2017 18:44:44
From another angle.
Sticky Wickett
#502 Posted : 20 April 2017 18:48:27
One more photo showing the frame work. I then proceeded to cut out a piece of 0.5mm plastic sheet to fit this area. This blanking sheet is what I will then build all the details on. At this stage is was just a dry fit and thus removable while I worked on it separately.
Sticky Wickett
#503 Posted : 20 April 2017 18:55:19
With the blanking piece removed I could mark out the centre line position of the mast well. From here it was a case of building up semi-circular shapes to represent the mast well formers. For this I started by cutting out two 22mm diameter discs from 0.5mm plastic sheet. I used a compass cutter for this job. When they were both complete I marked out the centre line of each then marked out a cut line 0.5mm on each side of the centre line to allow for the thickness of the blanking piece. By this process I produced 4 partially semi-circular discs which are to be used as formers for the mast well.
The attached photo shows the first two formers glued in place along the pre-marked mast well centre line.
Sticky Wickett
#504 Posted : 20 April 2017 18:56:35
Another photo of the first two formers in place with the third former alongside ready for fitting.
Sticky Wickett
#505 Posted : 20 April 2017 18:58:59
The photo shows some detail added to the lower former. This detail would in fact be a mast well drain where the water ingress from the periscope being lowered would collect and then pumped out later.
Sticky Wickett
#506 Posted : 20 April 2017 19:00:21
All four formers fixed in place.
Sticky Wickett
#507 Posted : 20 April 2017 19:01:18
Another photo showing all four formers fitted.
#508 Posted : 20 April 2017 19:08:32
Another really interesting update and some very precise work being carried out.
Sticky Wickett
#509 Posted : 20 April 2017 19:44:29
I then cut out a piece of 0.25mm thick, plastic sheet to wrap around the formers to make the mast well housing. The attached photo shows the 0.25mm thick sheet, cut and fixed in place.
Sticky Wickett
#510 Posted : 20 April 2017 19:45:38
Thank you Tony. Much appreciated!
Phil W.
Sticky Wickett
#511 Posted : 20 April 2017 19:47:17
Another photo showing the sheet wrapped around the formers.
Sticky Wickett
#512 Posted : 20 April 2017 19:48:43
Showing from a different angle.
Sticky Wickett
#513 Posted : 20 April 2017 19:52:54
To represent the seams on the housing, I cut and glued four equally spaced 1.5mm half round strips around it's diameter. This photo shows the first seam in place.
Sticky Wickett
#514 Posted : 20 April 2017 19:53:54
All four seams in place.
Sticky Wickett
#515 Posted : 20 April 2017 19:55:17
From another angle. At this point it's really starting to take shape.
Sticky Wickett
#516 Posted : 20 April 2017 19:57:21
Another view showing the mast well.
Sticky Wickett
#517 Posted : 20 April 2017 19:58:29
Looking up from underneath.
Sticky Wickett
#518 Posted : 20 April 2017 20:00:26
I then added some detail; four panels, two top and two bottom. These would of probably been access panels when the U-Boat was being built in dock.
Sticky Wickett
#519 Posted : 20 April 2017 20:03:25
All four panels in place. These were made from 0.5mm thick plastic sheet, cut to size and then bent to match the curve of the mast well before fixing.
Sticky Wickett
#520 Posted : 20 April 2017 20:04:39
This photo shows the panels from one side.
Guest (10)
This page was generated in 0.457 seconds.
