8 Pages «<23456>»
Gaeta Falcata (Gajeta Falkusa) by Jack.Aubrey, Marisstella, 1:20 Scale. Options
jack.aubrey
#61 Posted : 02 April 2017 08:45:20
Thursday, March 30, 2017
More details, the job begins to get interesting and fun. Now I'm back for 4/5 days in Milan, I plan to return to Pisa next Tuesday. So do not expect news soon.
#62 Posted : 02 April 2017 09:20:26
Very nice update and the finish you are using makes the whole thing look real.
jack.aubrey
#63 Posted : 12 April 2017 09:06:26
Tuesday, April 11, 2017
The work is progressing well, not at high speed, but it goes well and I'm having fun.
Today I finished the two decks at bow and stern and then I better refined the gunwale. I'm glad I guessed the suitable wood for decks. When I was back to Cinisello I did a little research in my personal timber store and found these light walnut strips that make a good contrast with the color of the other boat elements. Those supplied by the kit seemed me too dark for these task.
Now I must understand what are the next steps, so I have to study the plans/instructions to decide the correct sequence for installing the other details. However, the date of my return to Cinisello approaches and I definitely will not be able to finish this model in time. I must then decide whether to let him in Pisa waiting to complete it on my return next fall or bring it with me in Cinisello and finish it there, similarly as I did with the Viking ship model.
Should I decide for the latter, of course the other model (Brick de 24) I have in the shipyard at home would still remain idle.
Sincerely yours, Jack.
#64 Posted : 12 April 2017 10:56:24
Jack
Its always a treat when we get one of your updates.
Absolute perfection is all i can say - its just such a fantastic piece of model making.
jack.aubrey
#65 Posted : 12 April 2017 12:14:38
birdaj2 wrote:
Jack
Many thanks, Tony, for your positive appreciation. Thanks again, Jack.
#66 Posted : 12 April 2017 17:47:32
Very fine work as always, the model is a bit of a stunner
jason
Sticky Wickett
#67 Posted : 12 April 2017 18:22:22
Excellent work Jack!
jack.aubrey
#68 Posted : 13 April 2017 14:46:21
jason
Many thanks guys for your positive appreciations. Thanks again, Jack.
jack.aubrey
#69 Posted : 14 April 2017 22:25:27
Thursday and Friday, April 13-14, 2017
At the end I decided to install the seats . . .
There were some difficulties to solve, so I decided to do a test with some unused material. The first difficulty was to bend the strip which constitutes the seat, giving it a humpbacked curvature that was stable and, above all, reproducible in four equal pieces. At the end I opted for bonding two strips held to dry in a jig having per proper shape which gives it, once the glue is dried, an right curve.
Then I had to solve the problem of how to insert the seat in the right place. The following photo shows the solution I found.
Picture 02 shows the method I used to obtain the required shape for the seat.
The remaining images show the final result. I think it's a good achievement . .
More significant images will follow soon. Salutoni, Jack.
#70 Posted : 15 April 2017 05:40:12
Your Jig for the seat is a great solution, works well
#71 Posted : 15 April 2017 08:30:07
The wood being used in this model looks so nice. Its turning into a really beautiful model and such an unusual subject.
jack.aubrey
#72 Posted : 15 April 2017 12:27:36
Many thanks for your comments, Jack.
jack.aubrey
#73 Posted : 15 April 2017 12:34:55
Further images, greetings, Jack.
jack.aubrey
#74 Posted : 18 April 2017 22:53:46
Monday and Tuesday, April 17/18 2017
It 's time to get myself dirty with brushes and colors . .
More precisely I painted with a matt acrylic white part of the gunwales.
For the first time I experienced the suggestion I received sometime ago from a friend modeler (expert in plastic modelling) that explained me the trick to prevent paint managing to sneak under the masking tape. The trick is to apply a coat of transparent (and matt in this case) paint on the border area between the masking tape and the part to be painted before using the final color paint. This clear paint seals the microscopic cracks that inevitably form . . It works great, thank you rudyf-104.
I have also painted two wood strips in white: these are the wales to be applied immediately below the gunwale. My only problem: I do not know why but the acrylic white covering was poor and I had to apply many coats before obtaining a proper color. Luckily with the hairdryer trick I did not have to wait the paint getting dry between coats.
Finally I proceeded to color with black acrylic the outer part of the hull, leaving for the moment unpainted the part where the wales will be installed, still to be completed and glued. I will do this task in the coming days.
Greetings, Jack.
Sticky Wickett
#75 Posted : 20 April 2017 09:42:35
Nice touch with the paintwork.
Phil W
jack.aubrey
#76 Posted : 20 April 2017 12:30:53
Wednesday 19 April 2017
I installed the wales on top of the hull, just below the gunwales. Then I had to do some minor adjustments to cover the small damages caused during the gluing of these strips and, finally, a coat of matt transparent paint, or rather, slightly satin.
The real boat is completely polished black, but in a model I think a polished finish is not much suitable, so I opted for a compromise: a satin matt finish. This finish is well visible in the fourth image here below.
Regards, Jack.
jack.aubrey
#77 Posted : 20 April 2017 23:01:03
Thursday 20 April 2017
My stay in Tuscany is now approaching the end: next week I will be to the island of Elba for a short vacation that will allow me to see the island in the spring; people say it's very beautiful. Then again another 15 days and then I will return to Cinisello. The next important step for completing this model is the construction of the so-called "falke" (I think it is translated in frisate), but for me this is an activity that is still to be understood, so I prefer to delay it when I'll resume work on this model.
So now I'm carrying on small "integrative" activities like the one described below with images. These are tables that are positioned fairly freely, between seats and having different functions . .
Surely an important function is to serve as a table for the food, which is necessary to bring on board as these boats were in the sea from early morning to late evening . .
Another usage was to make life a little more comfortable on board, adding more seats. .
But, I think, the main function is to allow rowers to do their job, the picture below shows how the rowers work and we can understand that these boards put them in the most suitable position for rowing effectively. .
These are details not provided in the kit, but can be seen in the photographs of the real boats, so why omit them ?
To next time, Jack.
#78 Posted : 21 April 2017 07:39:43
Very nice pictures. You've done a great job on your build.
Chris Cool
#79 Posted : 21 April 2017 07:43:53
Some very nice craftsmanship gone into that. Nice pictures.
Sticky Wickett
#80 Posted : 21 April 2017 09:27:15
A beautiful piece!
Guest (6)
8 Pages «<23456>»
This page was generated in 0.210 seconds.
