thanks geoff, its very heavy as well. thanks for watching.
Looks great Steve Al
thanks al, would you like to build this?
Hi Steve just had Email to say next delivery has been dispatched  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
thanks for that phil, keep a look out at the letter box.
here is part 16. stevegbr attached the following image(s):
here are the parts for this issue. stevegbr attached the following image(s):
fitting the oil pump housing and lower pan. stevegbr attached the following image(s):
now lower pan. stevegbr attached the following image(s):
fitting the axle mounts. stevegbr attached the following image(s):
now assemble the transmission case. stevegbr attached the following image(s):
here is part 17. stevegbr attached the following image(s):
fitting the sump pan. stevegbr attached the following image(s):
continue the engine assembly. stevegbr attached the following image(s):
assembling and fitting the starter motor. stevegbr attached the following image(s):
fitting the engine bottom. stevegbr attached the following image(s):
here is part 18. stevegbr attached the following image(s):
fitting the filters. stevegbr attached the following image(s):
fitting the manifolds. stevegbr attached the following image(s):
Guest (14)
