106 Pages «<2728293031>»
Sticky Wickett
#561 Posted : 27 April 2017 08:25:56
A photo of the smaller, shorter pipe.
Sticky Wickett
#562 Posted : 27 April 2017 08:29:49
This photo shows the one end of the shorter pipe drilled out and an aluminium pin glued to the end. This pin will locate in a pre-drilled hole on the blanking plate. I had already marked out the pipe locations and drilled the holes when marking out the holes for the M1 bolts. The pins help strengthen the pipework when fitted, aid location and ensure they align.
Sticky Wickett
#563 Posted : 27 April 2017 08:30:32
The other pipe drilled and pin fitted.
Sticky Wickett
#564 Posted : 27 April 2017 08:31:07
The two completed pipes.
Sticky Wickett
#565 Posted : 27 April 2017 08:32:03
Central support fitted.
Sticky Wickett
#566 Posted : 27 April 2017 08:32:45
Another photo of the central support.
Sticky Wickett
#567 Posted : 27 April 2017 08:33:35
The central support from another angle.
Sticky Wickett
#568 Posted : 27 April 2017 08:34:32
Pipework fitted.
Sticky Wickett
#569 Posted : 27 April 2017 08:35:50
No3.MBT completed showing the mast well, supports, bolts and pipework.
Sticky Wickett
#570 Posted : 27 April 2017 08:37:45
Well that's it for this weeks post. I hope you enjoyed the process.
More posts to follow next week.
Thanks for looking in, have a great Bank Holiday weekend and happy modelling.
Kind Regards,
Phil W.BigGrin
#571 Posted : 27 April 2017 08:52:52
Wonderful detail being added and some great skills being shown.... Looking great Phil... Drool Drool
Sticky Wickett
#572 Posted : 27 April 2017 09:42:05
Markwarren wrote:
Excellent work as usual, looks stunning. Drool Drool
Thanks for looking Mark. I appreciate your comments.
Phil W.
Sticky Wickett
#573 Posted : 27 April 2017 09:43:15
Hi Alan, thanks for looking and I appreciate your comments.
Phil W.
Sticky Wickett
#574 Posted : 27 April 2017 10:20:10
Thank you for all the kind comments. Much appreciated.
Phil W.
Sticky Wickett
#575 Posted : 27 April 2017 10:21:41
In next weeks post I will be looking at dry fitting all the part-works supplied plastic bulkheads into the Control Room.
Until then, thanks for looking in.
Phil W.
#576 Posted : 27 April 2017 17:46:21
Phil
Fantastic as ever.
Was watching something on freeview last night about the latest us sub and i can relate to your periscope detailing better now.
In these new subs they have done away with the traditional periscope using video cameras on something they termed "the sail".
Apparently doing away with the traditional periscope gives them loads of room back. Something i have never thought abought when you watch the old ww2 type films.
Looking forward to your next installment.
#577 Posted : 27 April 2017 19:37:03
A superb update Phil, this is such a enjoyable build to follow.
Your scratch building is fantastic and really adding to the detail, I also love how you are showing each stage of the scratch building to show us how you got to the end result.
Eagerly awaiting more BigGrin Cool
Sticky Wickett
#578 Posted : 27 April 2017 19:44:03
birdaj2 wrote:
Phil
Fantastic as ever.
Thank you very much Tony. Much appreciated.
I just did a bit of research on the new photonic masts which have replaced periscopes. A quote from Wiki below;
"21st-century submarines do not necessarily have periscopes. The United States Navy's Virginia-class submarines and the Royal Navy's Astute class submarines instead use photonics masts,pioneered by the Royal Navy's HMS Trenchant, which lift an electronic imaging sensor-set above the water. Signals from the sensor-set travel electronically to workstations in the submarine's control centre. While the cables carrying the signal must penetrate the submarine's hull, they use a much smaller and more easily sealed—and therefore less expensive and safer—hull opening than those required by periscopes. Eliminating the telescoping tube running through the conning tower also allows greater freedom in designing the pressure hull and in placing internal equipment."
On my first submarine, HMS/M Opportune, a diesel/electric boat which for all intents and purposes was the same as a U-Boat in design and layout, the Radio Signalman was allowed to carry a small amount of brandy. Why? It was his job to clean the periscope lenses when in harbour!LOL
Mind you, my first job was to clean the outside of the windows [port-holes] when dived.LOL Joke! The boats don't have port-holes but the amount of times I used to get asked that and who cleaned them!LOL
Phil W.
#579 Posted : 27 April 2017 21:41:17
Another great update, your detail work is superb.
Sticky Wickett
#580 Posted : 27 April 2017 22:41:40
Thanks Dave. I really appreciate your comments and glad you're enjoying the build. I was thinking maybe I was uploading too many photos and being overly detailed, but if you and other members enjoy looking at the different stages in scratch building then i'm happy with that!BigGrin
Phil W.
Guest (13)
This page was generated in 0.363 seconds.
