So pleased to see you back with us all and posting again. Life has its ways of causing us problems at different times but i am pleased you are feeling at the point were you can now pick up your hobby again. Your build is looking wonderful and it will be wonderful to see you progressing again with this one. Happy Modelling
Good to have you back Jonny, watching with interest
 Nice to see you back Jonny, onwards and upwards with the build Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,413 Points: 22,549 Location: Northamptonshire, England
Great to have you back, looks like you've contracted a more critical eye. Regards Mark Regards Markwarren (Mark) Admin
Great to see you back Jonny, you've been missed.... Hope your health is much improved and look forward once again to seeing your build progressing..... Regards Alan
It`s good to see you back and obviously ready to crack on with your Sots. Looking forward to seeing your input on the forum. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Good to see you back on your build, looking forward to seeing it progress.
Hi Jonny, Nice to see you back. Looking forward to see your progress. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
After my long break from my build, I seem to be missing two parts from the same issue. Does anybody know if I can still buy Issue 53 of SOTS from Deag??? Much obliged... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
jonny7england wrote:After my long break from my build, I seem to be missing two parts from the same issue. Does anybody know if I can still buy Issue 53 of SOTS from Deag??? Much obliged... Have PM`d an idea. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Jonny, you could try emailing sales@model-space.co.uk. You never know but they may just be able to help. Regards Alan
jonny7england wrote:After my long break from my build, I seem to be missing two parts from the same issue. Does anybody know if I can still buy Issue 53 of SOTS from Deag??? Much obliged... Jonny Not sure if it would help you but there is a part 53 on ebay at the moment with parts but is a little pricey ay£10.95 Here is the code 401266790762 Happy Modelling
Jonny Glad to hear its all moving in the right direction for you. It can be difficukt to pick up were you left off after a spell away but knowing your great works i am sure it will all go well for you. Happy Modelling
Jonny, your last photobucket image is not showing, you'll need to dump photobucket and find a new photoshare site or think about using the fix http://forum.model-space...sts&t=23676&p=3
Hi shipmate...I've been busy fiddling around with my SOTS build tweaking bit here and there and adding some more of the bling to her stern. I am at present on issue 67 where I am having issues with cutting out the holes in the deck bulkheads. A job that I thought would be a breeze until I remembered that I had to cut through wood which is not very workable with a craft knife, then finding the bulkhead strips coming apart near the top of the bulkhead..Curses..With some cussing I am slowly winning though. I am adding just one pic at this point...So, onward and upward me hearties... File Attachment(s): jonny7england attached the following image(s): Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
 Rank: Pro  Groups: Registered
Joined: 05/09/2012 Posts: 184 Points: 525 Location: ireland
Hi johnnie Those ports are very tough to cut out. I used a sanding bit to finally get the job done. Anyway great to see you back. Your build is looking fantastic. Keep up the good work mate.
 Hi Jonny the stern is looking brilliant  Cutting the holes are a real pain , to help stop them splitting out I found running ca glue down the seams helps hold them in place also I used drills in slowly increasing size to hand drill the holes and made up a dowel of the right size with some sandpaper wrapped around it to sand it to the right diameter Hope this helps rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Jonny, she's coming along beautifully and all credit to your patience.....  .. Drilling the holes can be a little dodgy especially at the very top of the bulkheads but Martyn has described the best solution, a dowel that is smaller than the required diameter with find sandpaper glued around it at one end. This method will give you far greater control than any drill bit or file....  .. Keep up the good work.... Regards Alan
Since Tuesday, (with the help from a fellow Model Space member to whom I will be forever grateful) I have spent quite some time trying to put together my SOTS build diary trying to fit photographs to the words...But, I'm very sad to say that I failed to rescue some of my pictures from a certain photo sharing site which can not be put back into my build diary leaving ugly gaps. Sadly, I have had to ask to have my Victory build diary to be removed all together...But, I shall continue the task of restoring this diary where I can and adding a few new pictures of my recent work on SOTS. And to that photo sharing site jonny7england attached the following image(s): Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
 Looking good my friend, lovely job on the gunports Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
