I thought I had finished my build until i had a bag left over from issue 19 with one greebly still attached to the sprue. Referring back to the instructions, it states to leave it out until later. Did I miss something?
The greebly from issue 19 goes on the top hull piece that was supplied in issue one. I can't sent you a pictures at the moment but if you look at a reference picture you should be able to see it. You will also find you have a small hole where it fits. Regards Mark Regards Markwarren (Mark) Admin
Oh, thanks Mark. Do you know which issue had the instructions to fit it?
Off hand no. When I get in this evening I'll have a look or send you a picture of it in place. Regards Mark Regards Markwarren (Mark) Admin
The addition of this part is covered in issue 24, you can see in the official build diary http://forum.buildmillen...n-build-diary-issue-24/
Hope this helps
Brilliant- thanks both for your help!
