106 Pages «<2930313233>»
Sticky Wickett
#601 Posted : 03 May 2017 23:09:11
This photo shows the deck head test fitted looking forward. I like this image as you can see the detail in No3. Main Ballast Tank [MBT] as mentioned in a previous post.
Sticky Wickett
#602 Posted : 03 May 2017 23:10:29
Deck head in place looking aft.
Sticky Wickett
#603 Posted : 03 May 2017 23:12:11
With all the parts in place i'm happy that I can now successfully paint and fit them out prior to fixing.
Sticky Wickett
#604 Posted : 03 May 2017 23:14:11
The next set of photos show the parts being removed in reverse order.
First, the deck head.
Sticky Wickett
#605 Posted : 03 May 2017 23:14:57
Next up, the deck being removed.
Sticky Wickett
#606 Posted : 03 May 2017 23:15:58
Port side bulkhead removal.
Sticky Wickett
#607 Posted : 03 May 2017 23:16:47
Removing the forward bulkhead.
Sticky Wickett
#608 Posted : 03 May 2017 23:17:36
Finally, removing the aft Control Room bulkhead.
Sticky Wickett
#609 Posted : 03 May 2017 23:19:07
Well that's it for this weeks build log update.
Thanks for looking in and happy modelling.
Phil W.BigGrin
#610 Posted : 04 May 2017 08:01:29
Excellent update, looking really impressive.BigGrin
Sticky Wickett
#611 Posted : 04 May 2017 09:29:16
Thanks for looking in Mark!BigGrin
Phil W.
#612 Posted : 04 May 2017 12:40:29
Phil
Its looking really good and you have been spot on with the accuracy of your assemble to get all of those internal parts to fit so neatly.
Sticky Wickett
#613 Posted : 04 May 2017 13:03:33
birdaj2 wrote:
Phil
Thanks for looking in Tony. It took a while [2 weeks] to get all these parts correct.
#614 Posted : 05 May 2017 15:33:05
Hi Phil another great update BigGrin do you think it`s better to modify the parts to fit the control roomConfused rather than chop the piece out then Confused ? regards PhilCool
Sticky Wickett
#615 Posted : 05 May 2017 15:38:37
Hi Phil, thanks for looking in. Yes, I do think it's worth modifying the parts slightly.
It works for me anyway. Chopping part of the hull out after it's been sanded, undercoated etc and then try and refit it right at the end if the build seems daft.
Phil.
Sticky Wickett
#616 Posted : 05 May 2017 15:42:16
One other thing Phil; as for getting the dremel out to make the parts fit, I would of had to do that even if I had removed the hull section as it was the MDF supports at the back stopping the plastic parts from fitting. It was easier to grind the plastic parts down than to try and file away the MDF supports when they're right at the back and difficult to get to.
Hope this makes sense!Blink
Phil W.
#617 Posted : 05 May 2017 15:46:56
Yes think you are right there PhilBigGrin didn`t want to start chopping bits outBlink think i`ll go down the same route BigGrin cheer`s BigGrin regards PhilCool
#618 Posted : 05 May 2017 17:05:40
Some more lovely work Drool
Will you be painta not up parts as you go or waiting until more has been done
Sticky Wickett
#619 Posted : 05 May 2017 17:29:36
Hi Dave, I'm currently working my way forward through the boat getting the internal compartments ready for paint. One compartment left; the Torpedo Compartment. I should have this ready by end of May. Then I can undercoat, topcoat and varnish all the compartments. They will all be ready then for fitting out. As for the exterior, there are some brass strips to add and they don't get issued for another 3 weeks or so. When they're on I can add the rivets and weld lines. These are embossed plastic. I didn't want to fit them yet in case they get knocked off while I'm still handling the boat a fair bit. The undercoat will seal them firmly. Once the compartments are painted I guess mid June the hull will see paint. It will really start to come to life then.
Thanks for looking in.
Phil W
#620 Posted : 08 May 2017 16:48:07
Nice scratch building of the vents.Love
Congrats on your "Orange" medal. Cool Cool
Guest (10)
This page was generated in 0.346 seconds.
