6 Pages <12345>»
Andreas modified T-72 Options
#41 Posted : 07 May 2017 22:27:45
Lovely work, very impressive. Drool
Andreas
#42 Posted : 13 June 2017 18:16:23
Groups: registriert
Hi everybody
Receiving delivery 5 wasn´t so much "action" i hoped for. But also these small things must be get done as well.BigGrin So i only could dip 3 small Body pieces and gave them the new camouflage. The next step by mounting the damage lamps for the hit display were also done quickly. This is also the case with the assembly of the chain links. Now hoping for the next delivery for a little bit more action.
Andreas
Forum Support Team
Metal Mech
#43 Posted : 13 June 2017 18:35:34
Looking good. How hard is it to do that dip coating stuff?
DeAgostini kit builds:
Shelby GT-500: 28% Complete
Andreas
#44 Posted : 13 June 2017 19:19:25
Groups: registriert
Hi Metal Mech,
with a little practice everybody can do it. Just try with a small component. Mistakes can be easily corrected. Simply dive the component again,without removing anything.Just dry the Part before you dip it again.
How to work with Water transfer printing you can find here. This is a guide to the procedure for working with water transfer printing i posted i little time ago
http://forum.model-space...spx?g=posts&t=14467
Andreas
Forum Support Team
#45 Posted : 13 June 2017 22:48:06
A lovely piece of work, she looks excellent.....Drool Drool
#46 Posted : 14 June 2017 06:57:38
Very nice, and very effective. Love
Andreas
#47 Posted : 16 July 2017 06:33:09
Groups: registriert
Hi Guys
In the construction phases of delivery 6 there was actually not much to do. Here I could only edit the side panels and the new camouflage. The chain links were assembled. The searchlight has been modified and equipped with an LED. The headlamp glass comes from Hummer H1, it fits exactly.BigGrin
best Regards
Andreas
Forum Support Team
#48 Posted : 16 July 2017 08:57:01
Wonderful looking build, very impressive....Drool Drool
#49 Posted : 16 July 2017 09:27:55
It's very eye catching, well done so far Cool
#50 Posted : 16 July 2017 09:47:50
Excellent build, a lot of work gone into that.Love
#51 Posted : 16 July 2017 11:22:21
That is a very intense camo scheme! Very nicely done!BigGrin
Metal Mech
#52 Posted : 16 July 2017 13:32:13
Love how well it's coming together. Can't wait to see the final result.
Andreas
#53 Posted : 16 July 2017 17:06:12
Groups: registriert
Hi everyone
Thank you very much , I appreciate it very much.
Yes I try to get the T-72 perfectly. The small components sometimes cause problems, but as you all know we keep on learning every day. So I keep going until it's the way I want itBigGrin
Andreas
Forum Support Team
#54 Posted : 16 July 2017 18:39:43
BigGrin Looking goodCool
#55 Posted : 16 July 2017 19:59:07
This looks better and better with each update, love it!! Drool Drool
Andreas
#56 Posted : 08 August 2017 18:58:57
Groups: registriert
Hi Guys next delivery ,next updatesBigGrin
The fourth stowage pannier
In this stage, the fourth stowage pannier (with rear fender) received his
comourflage and got fitted to the hull.
The gun, mantlet cover and track
With this stage some more parts for the main gun. the mantlet cover, in two parts, After receiving its Comourflage it was fitted around the main gun. Then the LED was mounted in position.
The recoil mechanism
The assembly of the recoil mechanism was the next step
The infrared receiver
After changing the colour of the infrared (IR) receiver it was fitted on the turret. Easy job,nothing spectacular.
The circuit boards and left skirt
With receiving the three circuit boards, which two where mounted „the game“ was over.
Forum Support Team
#57 Posted : 08 August 2017 19:39:42
Looks amazing Andreas, well done on an excellent build and thanks for sharing. Cool ThumpUp
Andreas
#58 Posted : 16 September 2017 07:08:12
Groups: registriert
hi GuysBigGrin
with delivery 8 unfortunately only a small update is possible. Here I could only mount the rotor.
The chain was extended by a few chain links.
At the end, the two external gas tanks were adapted in color.
The rest of the parts are stored until i receive the lower hull, which would be with Stage 60.
Forum Support Team
#59 Posted : 16 September 2017 09:13:27
A small update is better than no update especially when a build looks as good as this.... well done.....Cool Cool
#60 Posted : 16 September 2017 09:31:28
Nice work Andrea, very skilful. Well done. Cool ThumpUp
6 Pages <12345>»
This page was generated in 0.786 seconds.
