Planking using pins Options
Blue_Joe
#1 Posted : 20 March 2011 17:20:28
Is there any reason that when planking (which I'm finally about to begin somewhat apprehensively) you can't push the pin all the way in to hold the plank??
I only ask as I am going for a painted finish so once sanded (most likely filled!) and then painted you wouldn't see them?!
#2 Posted : 20 March 2011 18:08:16
Hi Blue_Joe, I started out planking not using pins and found that some of the planking sprang away from the points where they were originally glued to, The PVA glue I was using did not seem up to the job, but since then, I have been pinning my planks, pushing them halfway home then lopping off the heads before filing the nails even with the planks? i.e It is easier to file away the clipped nails rather than the heads...hope this helps...
BigGrin
StefanDV
#3 Posted : 21 March 2011 07:12:11
If you don't file away the heads on the pins they will be completely off-scale
Blue_Joe
#4 Posted : 21 March 2011 08:15:27
My point is once sanded and painted you won't see them! So scale is not going to come into it!
#5 Posted : 21 March 2011 10:22:26
This thread might assist you decision
http://forum.model-space....aspx?g=posts&t=2066
This page was generated in 0.187 seconds.
