contact glue Options
wallace
#1 Posted : 21 March 2011 13:55:43
Can anyone tell me where I can get contact glue and what is the best stuff to use, I have just started the Endeavor and I cant get contact glue from round here. would be grateful for any ideas.
thanks guys
Wallace
#2 Posted : 21 March 2011 14:39:33
Evo-stik is the most common brand name, available from B&Q or most DIY outlets
wallace
#3 Posted : 21 March 2011 14:44:20
Thanks very much Tomick.
jeff
#4 Posted : 21 March 2011 17:33:34
Rank: Beginner Level 1
hi wallace
i get mine from ebay £7.99 free delivery
this is for 1 litre tin because i use it quite a lot
but there are smaller tins availible
ebay sellers shop----discount fixings
jeff
Son of Bulwark
#5 Posted : 21 March 2011 18:38:51
Hi wallace! Cool
I used Evo-stick Timebond adjustable contact adhesive in the tube not a tin, as you can apply direct on the hull and planks by just rubbing the end of the tube over the wood. No need to use a brush or scraper the glue dries in 5 to 10 minutes then line up the plank on the hull it can be moved until you press it down.
When I line up the plank I bend the plank over my finger and up to the plank already glue, then run the plank along the hull so there is no gap between the planks. Next I roll the plank down with a wooden roller, any extra glue on the top of the plank can be rubbed off.
As Tomick said "available from B&Q or most DIY outlets"
#6 Posted : 21 March 2011 18:46:24
Hi,
This stuff is very good, its non stringing too.
Thixofix
Chris..
This page was generated in 0.100 seconds.
