 Rank: Pro Groups: Registered
Can anyone tell me where I can get contact glue and what is the best stuff to use, I have just started the Endeavor and I cant get contact glue from round here. would be grateful for any ideas. thanks guys
Wallace
Evo-stik is the most common brand name, available from B&Q or most DIY outlets
Joined: 20/09/2010 Posts: 6 Points: 24 Location: leeds
hi wallace
i get mine from ebay £7.99 free delivery this is for 1 litre tin because i use it quite a lot but there are smaller tins availible ebay sellers shop----discount fixings regards jeff
Hi wallace! I used Evo-stick Timebond adjustable contact adhesive in the tube not a tin, as you can apply direct on the hull and planks by just rubbing the end of the tube over the wood. No need to use a brush or scraper the glue dries in 5 to 10 minutes then line up the plank on the hull it can be moved until you press it down. When I line up the plank I bend the plank over my finger and up to the plank already glue, then run the plank along the hull so there is no gap between the planks. Next I roll the plank down with a wooden roller, any extra glue on the top of the plank can be rubbed off. As Tomick said "available from B&Q or most DIY outlets"
Hi, This stuff is very good, its non stringing too. ThixofixChris.. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
