 Rank: Pro  Groups: Registered
Joined: 04/07/2016 Posts: 297 Points: 897 Location: UK
Insert the two pins on the starter 2 into the holes on starter 1. Place the starter up against the front of the engine and add an AP screw. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Place the engine bottom underneath the front of the engine and fix in place with 2 JM screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Issue 18 Parts - Engine Back Engine Side Right Engine Side Left Fuel Filter Oil Filter Manifold Right Manifold Left 6x DM Screws 6x AP Screws spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Secure the fuel filter onto the right engine side with an AP screw. Do the same with the the oil filter. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Attach the right manifold (has a hole in the middle) to the right engine side and add 2 AP screws. Attach the left manifold to the left engine side with 2 AP screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Fix the right engine side to the engine bottom with 2 DM screw. Do the same with the left engine side. Then add the engine back to the engine bottom and add 2 DM screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Issue 19 Parts - Engine Top Auxiliary Air Pipe Pipe Water Hoses Water Pump Water Distribution Pipes 3x AP Screws 4x AM Screws Tweezers spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Fix the water pump to the water hoses with an AP screw. Push the ends of the water hoses into the engine top, turn the engine top over and add 2 AP screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Attach the water distribution pipes the the engine top and add 3 AM screws. Fix the auxiliary air pipe on to the engine top and secure with an AM screw. Add the pipe onto the auxiliary air pipe. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
A few pic off the last 2 issues of the Thunderbird 2, issues 3 and 4. I am very happy with the way it looks and can't wait till they bring it out. I don't like how the people are no use for them if all the vehicles are going to be on a display case.hey should add people that can sit in the seats that would be better. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
The engine parts on your car look nicely made. Hope it continues to go well. Happy Modelling
birdaj2 wrote:The engine parts on your car look nicely made.
Hi birdaj2 the engine parts are good but in some parts their are gaps witch need filling in with some filler but apart from that the parts fit together nicely. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Issue 20 Parts - Left Air Intake Right Air Intake Intake Bottoms x2 Intake Manifolds x3 16x AP Screws spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Push the 3 intake manifolds into the holes in the 2 crosspieces (do one at a time and make sure the 2 intake bottoms are the same way) then fix together with 6 AP screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Its all progressing very nicely. Happy Modelling
Fix the right air intake to the intake bottom and add 2 AP screws. (Note the right air intake has a grove and a curved section at one end) Add the left air intake in the same way. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Looks great spike. I take it you are enjoying the build.
Insert the assembly into the top of the engine aligning the holes of both sub-assemblies then add 6 AP screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
birdaj2 wrote:Its all progressing very nicely.
Thanks birdaj2 its coming along nicely the engine is big and got some weight to it. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
stevegbr wrote:Looks great spike. I take it you are enjoying the build. Hi stevegbr thanks yes the build is good and alot has been done saying its only were only on issue 20. How are you finding the build? Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Guest (6)
