Paint Options
#1 Posted : 12 May 2017 19:06:38
Hi all
For the build I will be using the following paints. The majority are from the Admiralty range by Caldercraft apart from the inner bulwark green and the gold colours.
http://www.jotika-ltd.co...768/PSA_Paint.htm#Paint
2 each
Primer, wood and metal.
Dull Black
Matt White
Bulwarks Dark Green;- Tamiya XF-70 A close match.
1 each
Red Ochre
Matt [Metal] Black
Gold.
Matt,Satin or gloss varnish for application as needed.
For the gold I will be using Vallejo's Liquid gold from there Metallic's set but like the undercoat you can use your prefered paint brand for any of the above if you wish.
#2 Posted : 12 May 2017 19:18:16
Hi Andy great information thanks
will the paints excluding primer and the green, be available in the Model space shop?
Also do you know if there will be a stand?
#3 Posted : 12 May 2017 20:03:16
The paint will not be sold in the Model Space Shop and no decision on the stand has been made as yet.
MFG
#4 Posted : 12 May 2017 23:35:49
Hi Andy,
Great information thanks, I'll be following your selection BigGrin
May.
This page was generated in 1.261 seconds.
