Hi guys. I seemed to have misplaced the 2 engine gaskets when I moved house. Only 2 parts that I'm missing. What's the best way about getting replacements, I live in Australia and are there similar gaskets that will do the same job for the gx21.
Thanks.
Email internatinal shipping...
http://forum.model-space...spx?g=posts&t=19289
You need to indicate which issue they are contained in as they only send out full content of each issue.
Thanks for your reply but $52 Aus seems a bit extreme for postage. I seemed to have found a potential replacement. Is anybody able to confirm?
Bazdoctor wrote:Thanks for your reply but $52 Aus seems a bit extreme for postage.
If you enquire, you might find they send you it totally foc.
Unable to confirm, you might try eBay for the issue.
Hi, I know this is 2 years on but I wanted the same gaskets and as Tomick says I had to purchase the complete stage to get them.
