10 Pages «<23456>»
May's Dream Jag Options
MFG
#61 Posted : 13 May 2017 18:24:03
Hi,
Issue 7
In this issue we continue with the door adding the window and the hinge, again no problems here, everything went together nicely Cool
May.
MFG attached the following image(s):
MFG
#62 Posted : 13 May 2017 18:31:04
Hi,
And finally for this month.....
Issue 8
Here we add the door panel, handles and trims. I very nearly got the two handles the wrong way around Blushing but luckily I noticed in time and was able to correct it and I also lost one of the screws but they provide a spare so I was ok. Leaving that aside I ended up with a beautiful looking door ThumpUp
Thanks for dropping by
May.
MFG
#63 Posted : 13 May 2017 18:34:29
Hi,
Yep I forgot to select the attach files icon Flapper
so lets try again.....
May
#64 Posted : 13 May 2017 19:25:00
Nice work May Cool
MFG
#65 Posted : 13 May 2017 21:15:22
Hi,
Thank you Al, is was a bit easier this month BigGrin now for another 28 day wait Sad
May.
#66 Posted : 13 May 2017 23:10:46
You're making great progress May and all looking good, well done.....Cool Cool
MFG
#67 Posted : 13 May 2017 23:57:09
Hi,
Thank you Alan, I'm pleased with how the parts are looking so far
ThumpUp
May.
#68 Posted : 14 May 2017 09:19:10
Nice update May. Coming together very nicely.ThumpUp
MFG
#69 Posted : 14 May 2017 11:54:28
Hi,
Thank you Mark much appreciated, the door and wheel both look really good and shows the quality of this build perfectly ThumpUp
May.
#70 Posted : 14 May 2017 14:37:53
So far so good May,
Following with interest
MFG
#71 Posted : 14 May 2017 15:27:19
Hi,
Thank you Jase,
I keep dropping things on the floor but apart from that all is well BigGrin
May.
#72 Posted : 14 May 2017 17:23:48
BigGrin Looking good MayCool
MFG
#73 Posted : 08 June 2017 12:47:51
Hi,
Thank you Andy, sorry for the late reply (I keep doing that Blushing)
May.
MFG
#74 Posted : 08 June 2017 13:10:32
Hi,
This months delivery arrived this morning featuring issues 9, 10, 11 and 12.
Issue 9
Strangely enough the back rest of the seat was already attached to the seat base so all I had to do was attach the seat cushion.
TBH I am a little disappointed with the back rest, first of all the stitching doesn't line up with the seat, the two vertical lines on the cushion aren't central to the arch stich line on the back rest there slightly to one side and no matter how I tried I just couldn't get it to look right. The link below is the picture of the seat from Spal's official diary and it shows the same finish as mine so it must just be how they've done it.
http://forum.model-space...k/resource.ashx?a=90135
And secondly it's appearance is flat with very little padding when compared to the beautifully produced seat cushion. I did have the idea of padding it out with a little bit of stuffing but on closer inspection this wouldn't really be achievable without removing the leather cover first so I opted to play it safe leave it be......although I may very well return back to this at a later date when I'm feeling a little braver BigGrin
May
MFG
#75 Posted : 08 June 2017 13:16:23
Hi,
Issue 10
Carburettor part 1
In this issue we start the Carburettor assembly which I assume is a very important part of the engine BigGrin Flapper BigGrin
I did find that it was a bit easier to leave the shaft of the build whilst going through the rest of this months issues as it kept on falling back out again but apart from that all was well.
May.
#76 Posted : 08 June 2017 13:21:22
May
Glad to see your build coming on so well.
Hope it all continues well for you.
MFG
#77 Posted : 08 June 2017 13:24:21
Hi,
Issue 11
Carburettor part 2,
The petrol feed pipe (what ever that is BigGrin) looked a bit fiddly in the instructions but it actually went on easily enough and the rest of the tasks were fine to follow, although I did keep up with tradition and dropped a couple of the screws, it's a good job they provide spares Blushing
May.
MFG
#78 Posted : 08 June 2017 13:26:23
Hi Tony,
Thanks for that, have your subscription problems been resolved yet?
May
MFG
#79 Posted : 08 June 2017 13:34:43
Hi,
Issue 12
Engine Block part 1,
The magazine notes an option to paint the Block black and gold, I've decided not to do this as I haven't got the paint or brushes etc but also it looks awkward to do and I didn't want to mess it up, so again I'm playing it safe.
As for the tasks I found it a bit easier to take the Air Cleaner installed in the last issue back of again whilst fixing the Carburettor to the Block but apart from that all was well
Well that's all for this month, thanks for dropping by
May.
stevegbr
#80 Posted : 08 June 2017 13:46:36
looks very nice and polished may. BigGrin
10 Pages «<23456>»
This page was generated in 0.317 seconds.
