7 Pages «<4567>
1/43 scale Bedford HA Van Options
Sticky Wickett
#101 Posted : 15 May 2017 23:12:44
Windscreen wipers from another angle.
#102 Posted : 15 May 2017 23:15:07
Adding the wipers is a very nice touch, adds very nicely to the detail of the build.....Drool Drool
#103 Posted : 15 May 2017 23:18:22
Nice touch and excellent work, they look the part.Love
Sticky Wickett
#104 Posted : 15 May 2017 23:19:36
On each side of the full size van there are two small badges just forward of the doors. These badges read HA 110 with the HA in white on a blue background and the 110 in black on a white background.
I made up two of these initially in excel. Imported them into Paint to crop and finally imported into Power Point to resize.
Once printed i then cut them out leaving a large border, glued them to a 0.25mm plastic sheet and finally stuck selloptape over the top to laminate them. When dry I cut to size and glued in place.
Sticky Wickett
#105 Posted : 15 May 2017 23:20:14
They add a nice level of detail.
Sticky Wickett
#106 Posted : 15 May 2017 23:21:11
Next part of the build I painted the rear light clusters.
Sticky Wickett
#107 Posted : 15 May 2017 23:22:46
I painted an aluminium rim around the lights before applying the orange, white and dark red lenses.
Sticky Wickett
#108 Posted : 15 May 2017 23:23:19
Front indicators painted.
Sticky Wickett
#109 Posted : 15 May 2017 23:25:47
What I like about this kit is the amount of white metal parts as it gives the scope to polish them up and leave natural rather than painting. You can't beat the look of real metal and the front grille is one of these parts.
I gave it a good rub with Brasso before fitting a tiny Bedford badge to the centre.
Sticky Wickett
#110 Posted : 15 May 2017 23:27:07
A close up of the Bedford badge. This was made in the same way as the HA 110 badges I mentioned earlier.
Sticky Wickett
#111 Posted : 15 May 2017 23:28:27
The finishing touch for the interior was to glue in place the book on Welsh rugby in the 1970's. I positioned this book resting on top of the dashboard.
Sticky Wickett
#112 Posted : 15 May 2017 23:29:13
The book from another angle.
Sticky Wickett
#113 Posted : 15 May 2017 23:30:57
The next part was the fitting of the wheels. I painted the centre rims in chrome silver and left the outer rims natural.
Sticky Wickett
#114 Posted : 15 May 2017 23:32:08
Another photo of the wheels.
Sticky Wickett
#115 Posted : 15 May 2017 23:34:00
Next up I gave the rear bumper a good polishing with Brasso and fitted the rear number plate. The number plates were made in the same way as the Bedford badge.
Sticky Wickett
#116 Posted : 15 May 2017 23:36:37
Rear number plate fitted.
Sticky Wickett
#117 Posted : 15 May 2017 23:38:01
Exhaust tail pipe fitted. It makes so much difference to appearance since I drilled out the end to make it look more like a pipe.
Sticky Wickett
#118 Posted : 15 May 2017 23:38:37
Exhaust tail pipe.
Sticky Wickett
#119 Posted : 15 May 2017 23:39:45
Side view with exhaust pipe fitted.
Sticky Wickett
#120 Posted : 15 May 2017 23:40:25
Front bumper and number plate.
7 Pages «<4567>
This page was generated in 3.185 seconds.
