13 Pages «<34567>»
Panart 1/16 Victory Sloop Build Options
#81 Posted : 10 May 2017 22:45:25
Chris, Walter thanks for looking in, appreciate the kind comments....Cool Cool
#82 Posted : 13 May 2017 23:39:24
A little more progress has been done. Finished fitting the new internal frames and glued them in place. Next job on the agenda was to plank the outer stern, these were laid in a horizontal fashion. Once done moved onto to planking the internal stern section but this time planked in a vertical direction.Cool Cool.. Finished covering the keel at the stern and the bow, this included the internal areas... Cool Cool ..
Until next time, happy modelling....
#83 Posted : 14 May 2017 08:51:30
Very neat work Alan.
That internal stern planking looks real tricky but you have done a lovely job on it.
#84 Posted : 14 May 2017 17:21:26
BigGrin Very nice workCool
#85 Posted : 14 May 2017 19:33:30
Superb work Alan Cool looking forward to the next instalment.
#86 Posted : 14 May 2017 22:26:24
Thanks guys, more will be posted in the next couple of days.... appreciate the comments....Cool Cool
#87 Posted : 14 May 2017 22:28:51
That looks sweet.
Cool Love Cool Love Cool
#88 Posted : 14 May 2017 23:24:26
Great work Alan she's coming along nicely.
Chris Cool
#89 Posted : 15 May 2017 22:51:42
Derek, Chris, thanks for the kind comments, appreciated....Cool Cool
#90 Posted : 15 May 2017 23:09:39
A little more work on her where I started to build up the handrails. First task was to take four strips of 2 x 10mm walnut, two for outside the hull and two for inside. These then had to be bent to follow the profile of the hull and to do this I simply used the plank bender tool available through the ModelSpace Shop. Details can be found here:
http://forum.model-space...spx?g=posts&t=22531
Once happy with the contours I then glued them in place, did this one at a time ensuring the glue was completely dry before fixing the next strip, trimmed the strips at the stern when done...Cool Cool .. The rubbing strake was next, this was again single strips of 3 x 3mm walnut. Once again the planking tool was use to bend the strip to the required profile. Glued and clamped the strips in place and left to dry. Trimming at the stern will be done after I have fitted the capping, this is the next task so until then...
Happy modelling all....
#91 Posted : 16 May 2017 08:26:33
Looking very nice Alan.
DaDokta
#92 Posted : 16 May 2017 08:43:32
That`s looking great!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#93 Posted : 16 May 2017 09:15:23
Looking really good Alan.
Phil W.
#94 Posted : 16 May 2017 23:55:47
Thanks for commenting Tony, Walter and Phil, appreciated as always....Cool Cool
#95 Posted : 17 May 2017 08:06:36
Another fantastic update Alan. Doing a great job.
Chris
#96 Posted : 17 May 2017 14:52:08
Stunned no work Alan Drool
Is the hull as delicate as it looks?
#97 Posted : 17 May 2017 20:47:31
looking really good AlanCool
bole13
#98 Posted : 17 May 2017 21:57:37
Rank: Beginner Level 3
Very nice work.
tnequette
#99 Posted : 17 May 2017 22:00:59
Alan,
Your planking work is beautiful. These smaller scales are great to work with.BigGrin
Tom
#100 Posted : 17 May 2017 23:35:20
Thanks once again everyone for the kind comments, appreciated... Will be posting again very soon...
@Dave, the hull is quite fragile until you get the second planking layer in place and even then it is easily cracked. As the build progresses and more pieces are added the hull gains in strength where now she is feeling fairly secure but am still handling with care...Cool Cool Cool
13 Pages «<34567>»
