11 Pages <12345>»
Vw Golf 2 GTI Tuned 1/8 Build Options
#41 Posted : 17 May 2017 23:14:27
It's a pleasure to see your skill producing some very nice work, looks fab....Drool Drool
#42 Posted : 18 May 2017 00:54:23
Those seats are great and look even better now you have worked your magic on them Cool
#43 Posted : 18 May 2017 07:49:35
Excellent job on the seats.BigGrin
Sticky Wickett
#44 Posted : 18 May 2017 10:19:42
Those seats look excellent!Blink
Phil W.
frah2o
#45 Posted : 19 May 2017 09:38:48
Thanks guys! Love
Continuing with the project, i found some new spare bit directly from Delta.
I find my new sport steering wheel. I try to flock the crown, i'll paint the spokes in alu. But before to made it, i'll wait the steering hub.
Finally i decided for the sport seat combo color.
I'll spray in coral the kevalr chassis. I think that kevlar is not appropiate for my project.
If in the engine bay would be a 500+ hp engine (such a 1.8 T or a VR6 turbo), i think that kevlar seat, race interior with only two seat, fire extinguisher, Stack race instrument and other race stuff will be perfect.
But my idea is an custom show ride with some sport/race parts but inside the original context
So i primered the first chassis, but before to piant, i'll must remove the juncton lines.
frah2o attached the following image(s):
frah2o
#46 Posted : 22 May 2017 06:23:30
After smoothed the chassis, I re-primered it nad finally the new coat. After a little black on the hole for the belt, the first seat is completed. Now I'll wait the future Delta issue to try the 5 point safety belt.
#47 Posted : 22 May 2017 08:04:11
Nice work, coming along great.
#48 Posted : 22 May 2017 11:49:05
Great progress Cool loving the recaro seats.
AL
frah2o
#49 Posted : 05 June 2017 07:28:37
Thanks mates. Love
While i'm working on Shelby parts i sanded, primered ans painted the second seat of my GTI. Now the front seats are completed.
frah2o
#50 Posted : 19 September 2017 10:07:51
Not so much to show. I'll wait the full body and front fenders to work on height ride.
The only news is that the 4 point seat belt for my project is arrived.
RM1
#51 Posted : 19 September 2017 12:12:00
They look great !! If possible could you let me have the details of those please?
Thanks. malc.
#52 Posted : 19 September 2017 14:38:50
This is really looking superBigGrin love those harnessesDrool regards PhilCool
frah2o
#53 Posted : 20 November 2017 08:28:03
This past weekend I continued with the GTI that has a lot adjustments and improvements to do.
In the last step I was arrived to the exhaust system, the next steps (watching the instructions) are various components fixed at the bottom of the floor.
1: Fuel pump and filter are really ugly out of the box. I've looking at some of the photos on the of the original pump and some modified pump.
I made a mix. I separated the funnel directly from the pump and gave a bit of detail between aluminum and gold then black washed. The tube from the pump to the filter was all colored in aluminum and then made in metallic blue the joints.
Finally the fuel filter is colored in aluminum. Everything then received a black wash.
2. The black frame components are original, but fitted on the subframe they is very hard to see them. I watch out a variety of customized golf 2 and I found a people who has reshaped them of a color that that I like and I try to replicate it.
I painted everything in aluminum and then I sprayed two coat of tamiya smoke.
I have redone all the aluminum bolts and finally I have detailed in red color the polyurethane bushes (as the powerflex kit)
3. The braking system is not bad but too flat. I removed the print marks on the inside of the disc and then repainted them all.
In the beginning I wanted to drill the disks, but watching my rims I decided to leave it as original. The only extra detail that I do(and this is the first time I try) was to apply aluminum tape on the disc brake track ... the result seems to me quite acceptable.
The brake calipers need to reworked, after finishing I paint them in gloss black. I painted in gold the calipers and finally I do a final smoke coat. I painted in black the brake pads and some little details
Next step will be the driveshaft.
kpnuts
#54 Posted : 20 November 2017 09:16:56
Amazing work. Looking really great.
frah2o
#55 Posted : 21 November 2017 07:50:18
Thanks to much Kpnuts.
Yesterday i began the work on driveshafts. I Remember my own on my GTI and look something on internet. I did some little extra detail to improve the look: I detailed the joint bolts on the differential, painted the inner joint with gun metal and finally with aluminum stripes I selfmade the ties.
I painted in semi-gloss black the arms between the joints. This evening I hope to finish the front axle group.
I did a first fitment test with disc brake and it seems ok. I used another rims. The definitive ones will be the whites that still need a detail processing.
#56 Posted : 21 November 2017 11:08:36
Your attention to the details never ceases to amaze me - you are such a skilled model maker and this build is a treat to follow.
Hope it all continues well.
#57 Posted : 21 November 2017 21:07:58
Great to see this coming together BigGrin looking good.
frah2o
#58 Posted : 22 November 2017 08:16:42
Thanks very much mates. It's a very good forum with fantastic people.
Yesterday I moved the first step with ride height.
I mounted the driveshafts on swinging arms. To reach the wanted height I must work on driveshafts. The longer one need little work, but the other side (the left side) was too long. I shotned it and i did the new splice with toothpick.
I made a test fit with original height and suddendly with my new ride height. I think that i found my lowering
Suddendly I made some extra detail on the chassis with fuel pump bracket and fuel tank brackets.
#59 Posted : 22 November 2017 08:57:03
Excellent work, your attention to detail is second to none.Cool
#60 Posted : 22 November 2017 11:39:28
Really top detailingDrool Drool you are doing looks great so far Cool regards PhilCool
Guest (10)
11 Pages <12345>»
This page was generated in 0.332 seconds.
