106 Pages «<3334353637>»
#681 Posted : 18 May 2017 08:37:01
Great scratch building yet again PhilDrool BigGrin you could probably do with shares in evergreen plasti cardLOLLOL have you got any pictures of the white metal fittings for the interior would be nice to see them regards PhilCool
Sticky Wickett
#682 Posted : 18 May 2017 08:38:58
birdaj2 wrote:
Awesome detailing.
Its going to be such a fantastic build when complete.
I have been collecting this one for that "future date " when i have more time on my hands than i know what to do with as experience shows once these partworks are gone on the whole they are gone forever.
I think i have 2 deliveries left on this one and will then see what else takes my fancy BigGrin
Really enjoying watching your work on this one.
Glad you like the build log. I pick up issue 142 this week, then only 8 issues left to collect, but still over a years worth of building left to do!Blink
Phil W.
Sticky Wickett
#683 Posted : 18 May 2017 08:40:39
Well that concludes this weeks update. Next week I will be carrying on with this compartment adding the finishing touches.
Thanks for looking in, have a great weekend and happy modelling.
Phil W.BigGrin
#684 Posted : 18 May 2017 09:27:12
Sticky Wickett wrote:
birdaj2 wrote:
Awesome detailing.
Phil W.
And that is were the value for money comes in Phil. You can get plenty of build time and enjoyment from these partworks.
Sticky Wickett
#685 Posted : 18 May 2017 10:04:33
birdaj2 wrote:
Awesome detailing.
Phil W.
Totally agree with you on that one Tony.
Sticky Wickett
#686 Posted : 18 May 2017 10:08:23
Hi Phil,
LOL Shares in Evergreen.
I haven't got loads of fittings but some. The rest I will scratch build. I'll dig them out and pop some pics on here over the next few days.
Phil W
DaDokta
#687 Posted : 18 May 2017 11:20:49
Another great update! Thanks!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#688 Posted : 18 May 2017 11:37:34
Thank you Walter!BigGrin
Sticky Wickett
#689 Posted : 24 May 2017 20:43:16
Good Evening from 'The Dockyard'.
This weeks log of my U230 U-boat build will be making the trim that sits above the Senior Rates Mess. This part is scratch built and continues the theme running along all of the compartments so far.
I started by making the backing piece from 0.25mm thick plastic sheet. The attached photo shows it cut to size.
Sticky Wickett
#690 Posted : 24 May 2017 20:44:29
The backing piece being test fitted.
Sticky Wickett
#691 Posted : 24 May 2017 20:47:32
The next task was to add the border using 1mm square strip. In the photo you can see that I held the border in place using clips to ensure it ran true to the backing piece edge. I left it slightly over length as it was easier to trim once fixed rather than try to get the ends to align.
Sticky Wickett
#692 Posted : 24 May 2017 20:49:38
The opposite border fixed in place. This required a bit more patience in aligning as the backing piece has a contoured edge.
Sticky Wickett
#693 Posted : 24 May 2017 20:50:50
A close up photo of the two borders.
Sticky Wickett
#694 Posted : 24 May 2017 20:51:59
The two borders trimmed and the whole piece test fitted.
Sticky Wickett
#695 Posted : 24 May 2017 20:56:48
Once the two longest borders were trimmed I made the end pieces in the same fashion.
Once this was done I began to add the transverse strips. These were made with 2.0mm wide x 0.5mm thick strip. The spacing between these tranverse strips was 8.5mm. They were all cut as I went so that each piece fitted correctly.
The photo shows the end border in place and the first transvers strip cut and ready for fitting.
Sticky Wickett
#696 Posted : 24 May 2017 20:58:41
The first transverse strip fitted.
Sticky Wickett
#697 Posted : 24 May 2017 20:59:51
All transverse strips fitted.
Sticky Wickett
#698 Posted : 24 May 2017 21:01:07
The completed trim being test fitted.
Sticky Wickett
#699 Posted : 24 May 2017 21:02:20
Looking aft.
Sticky Wickett
#700 Posted : 24 May 2017 21:02:55
Looking forward.
This page was generated in 0.430 seconds.
