Plastic glue and PVC glue Options
Gentlegiant
#1 Posted : 18 May 2017 17:07:18
Rank: Beginner Level 1
What kind off glue is the best for the Senna MP4/4 ?Confused
Metal Mech
#2 Posted : 18 May 2017 17:14:47
I can't specifically state anything about that kit as I haven't built it yet, but for plastic parts on model rockets I like to use Loctites two part plastic glue. I can post up the exact details when I get home if you like. It's very easy to use and has a nice strong bond.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
figuerres
#3 Posted : 18 May 2017 17:35:26
depends on what you need to glue to what, plastic glues will not work for metal, if i read the page right there are two kinds of non metal parts so you might ned two kinds of glue if you need to use glu on both kinds of plastic.
have you got the kit yet ? the magazines should give advice on the types to use *IF* you even need them.
my fallback for general stuff is locktite gel and weldbond.
depending on the material and how fast i need it to set up.
#4 Posted : 18 May 2017 19:53:06
The first months magazine goes through the different glues for this model.Which glue you need depends on what you are gluing.Plastic to plastic or plastic to metal
mattsr
#5 Posted : 19 May 2017 17:31:46
I find this absolutely brilliant:-
http://www.palmermetals....op/g-s-hypo-cement.html
It comes with a needle-thin applicator nozzle which means you can apply it in very small amounts, reducing the risk of getting it onto places you shouldn't....Blink
This page was generated in 0.100 seconds.
