Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
Would it be TOTALLY out of place to use a really fine chain for the hand rails? I just personally think it would look better. You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
The norm appears to be rope as is the case even on the Jotika Victory, though what is used in reality needs some research, though I'm guessing it is rope. Ultimately you can use whatever you think looks best in accordance with personal choice.
Thanks Tomick - historical acuracy is not THAT important so I don't mind going against the grain on minor details. You do not need a parachute to skydive. You only need a parachute to skydive twice.
A chain would certainly give a sense of movement, you might also want to consider a blackening agent for the eyebolts
