16 Pages «<45678>»
Krick 1:50 Scale Gulnara Build Options
#101 Posted : 16 May 2017 20:06:13
#102 Posted : 18 May 2017 20:03:35
Added some more detail to the paddle boxes, the two upper platforms have been added along with the three steps each side these will have turned brass stanchion's added later in the build.
I also added some lead sheet to the engine house's where the roof joins to the paddle boxes.
More soon.
#103 Posted : 18 May 2017 20:11:40
It gets better and better.
Love these paddle wheel ships a lot and this is such a nice model by a maker i had never heard about ubtil you posted this.
#104 Posted : 18 May 2017 21:06:03
She's coming along beautifully, great build.
#105 Posted : 18 May 2017 23:28:41
Looking great Andy, excellent work...Drool Drool
DaDokta
#106 Posted : 19 May 2017 07:13:56
She looks better and better - beautiful build!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#107 Posted : 19 May 2017 07:49:52
Looking very sweet so far, well done Cool
Sticky Wickett
#108 Posted : 19 May 2017 10:10:03
Excellent work!
Phil W.
#109 Posted : 19 May 2017 13:52:27
Looking better every time I see it Cool nice work Andy.
#110 Posted : 19 May 2017 21:14:22
BigGrin Thanks for looking in and your comments everyone very much appreciatedCool
#111 Posted : 19 May 2017 21:17:54
BigGrin The sail set has arrived, all pre stitched and made from heavy weave cotton. A little too white but easily cured with a dose of tea to darken them downCool
nightwisher
#112 Posted : 19 May 2017 21:59:38
Wow, now that is white. Definitely time for a cuppa tayBigGrin
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#113 Posted : 19 May 2017 22:37:46
Great work as usual
#114 Posted : 20 May 2017 08:35:28
#115 Posted : 20 May 2017 09:25:29
BigGrin Get the kettle on Andy I had to do that with the sails on the Vasa far to white Cool
#116 Posted : 20 May 2017 10:21:18
Nice work Andy, turning into a beauty.BigGrin
#117 Posted : 20 May 2017 19:00:30
#118 Posted : 21 May 2017 10:32:00
Andy. build is looking so good, quit fancy this myself. like the touch of leadCool
#119 Posted : 21 May 2017 18:38:13
BigGrin Thanks for looking in and your commentsCool
#120 Posted : 21 May 2017 18:48:28
The upper hull, paddle boxes and inner bulwarks has now had three coats of varnish to match the lower hull.
Whilst waiting for the Varnish to dry I started making up the deck furniture, The main parts consist of an inner ply former that is glued together then they are planked and sanded back, the two hatches you can see are ready for planking where as the sky lights are finished apart from the brass grills.
The round houses are formed of pre cut scallops of white ply and teak ply and then planked. The winch is made up of pre-shaped parts and is a case of assembly after adding the notches to the central ratchet of the winch. The gratings were made up in the usual way and then the surrounds added.
More soon.
Guest (6)
16 Pages «<45678>»
This page was generated in 0.260 seconds.
