13 Pages «<45678>»
Panart 1/16 Victory Sloop Build Options
#101 Posted : 18 May 2017 07:59:07
Very nice work Alan, look excellent. I'm looking at starting something similar soon, once I've finished the Falcon, so I'm trying to get as many tips as possible, and I'll be watching your progress, as I'll probably be out of my comfort zone with it.
#102 Posted : 18 May 2017 23:33:38
Thanks Mark, appreciate you looking in and commenting....Cool Cool ... This one is a challenge purely due to the way the hull is constructed so I wouldn't say this one is for someone who hasn't built a plank on frame kit before.. I'd recommend doing something like the Swift first and if that's successful then have a go at something like this.... Have to say though this is a very enjoyable build to do....Cool Cool
#103 Posted : 18 May 2017 23:42:42
Moved the build forward a little more by capping the handrail. This is capped with a walnut strip and that means having to cut the strip into trapezoid shapes in order to follow the profile of the handrail. Once fitted it was then a case of sanding everything smooth on the inside and outside of the rail.Cool Cool .. Then moved to fitting the rubbing strake to the stern and finishing that area off....
Now moved onto to shaping and test fitting the framing for the flooring. Everything under this framing will not be seen so to add additional strength to the hull I painted that area over with diluted PVA and left to dry, hull certainly feeling a lot more secure now... Last thing I did for this session was to glue the framing in place. Next we start to add some of the detail so until then, happy modelling all....Cool Cool
DaDokta
#104 Posted : 19 May 2017 07:12:28
As always great work! I guess it wasn`t easy to bring that handrail in the right shape!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#105 Posted : 19 May 2017 08:50:34
Thanks Walter, the handrail wasn't too bad but being walnut then trying to bend laterally is a no-no. The strip s wider than the rail so by cutting into trapezoid sections and taking a little care means it will cover the rail with little problems....Cool Cool
Sticky Wickett
#106 Posted : 19 May 2017 10:12:25
Very nice work on the hand rails Alan. Great job!
Phil W.
#107 Posted : 19 May 2017 13:56:28
Coming along very nicely Alan Cool a really clean build.
#108 Posted : 19 May 2017 22:44:34
Phil, Al, thanks for looking in and commenting, appreciated as always....Cool Cool
#109 Posted : 19 May 2017 22:52:20
Stunning work Alan. Great pictures aswell. Love watching this.
Chris.
#110 Posted : 19 May 2017 23:31:32
Nice work Alan, taking shape nicely.BigGrin BigGrin
#111 Posted : 20 May 2017 06:07:47
comping along very well, the finish is loverly
#112 Posted : 20 May 2017 08:34:42
BigGrin Nice work AlanCool
#113 Posted : 20 May 2017 10:59:44
Thanks for the positive comments guys....Cool Cool
#114 Posted : 20 May 2017 14:47:23
that is looking really nice Alan.
Such a perfect fit you have achieved with all of the parts.
its turning into a very attractive model.
#115 Posted : 20 May 2017 23:08:03
Thanks Tony, appreciated as always.....Cool Cool
#116 Posted : 23 May 2017 22:59:54
A little more done to this one. Planked the forward and stern bulkheads as well as the bow deck with walnut strips, gave it all a fine sanding followed by 2 coats of Danish Oil, think it really brought the grain out to good effect. Cool Cool. Next was to carry on building up the flooring, adding the framework to take the gratings and various other fittings, these will be shown later in the build. Cool Cool
More soon....
#117 Posted : 24 May 2017 06:14:33
BigGrin Stunning work as always Alan Cool
DaDokta
#118 Posted : 24 May 2017 06:39:41
Everything looks so neat and tidy! Great work!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#119 Posted : 24 May 2017 08:36:23
Beautiful work as always and the Danish oil certainly works on the grain well. Great job.
#120 Posted : 24 May 2017 13:16:16
Lovely work Alan Cool like the colour of the walnut planking.
13 Pages «<45678>»
This page was generated in 0.624 seconds.
