Getting started Options
CaptnBirdseye
#1 Posted : 25 March 2011 20:41:51
Rank: Superelite
Hi guys.
Now my subscription problem has been sorted (thanks admin), i want to get prepared for the build. In Tomick's build diary, he recommends the use of a build board. Does anyone know what size to use?
Also i have most hand tools that i thinki am going to need, but are there any specialist tools needed? I'm thinking here about the metal parts supplied.
Any help greatfully received.BigGrin
#2 Posted : 25 March 2011 21:14:28
My board was 45" long 8" wide.
No specialist tools required other than basic modelling tools, you will receive a small file for the metal parts in pack 1.
CaptnBirdseye
#3 Posted : 25 March 2011 22:13:04
Rank: Superelite
Thanks Tomick......better start looking then!
farrabass
#4 Posted : 27 March 2011 14:36:53
Just to let you know, I bought a cheap pine shelf kit and a set of angle brackets from Lidl, total cost around £6. The shelf is about 3ft x 6in.
Hope that helps..
#5 Posted : 27 March 2011 14:59:47
Just be mindful that the shelf is perfectly flat and not warped as pine on occasion tends to be, otherwise your hull will follow the warp.
CaptnBirdseye
#6 Posted : 05 April 2011 22:15:05
Rank: Superelite
I have received the firdt build instructions but as yet no parts. On the 22 month build, how many parts do we get with each delivery? The instructions for part one cover the hull, bridge and range finder. Do all these parts come with the first delivery?Drool
#7 Posted : 05 April 2011 22:53:22
One would asume that the first batch of instructions ties up with the parts that are on their way.
CaptnBirdseye
#8 Posted : 06 April 2011 21:40:30
Rank: Superelite
Yeah!!That is good newsBigGrin I didn't know if one set of instructions were available for the 11 and 22 month subscriptions both.
Just need the delivery now
Trotsky
#9 Posted : 06 April 2011 23:09:50
Good Luck with the build
H.M.S Victory
H.M.S Victory X Section
D-51
CaptnBirdseye
#10 Posted : 08 April 2011 20:55:05
Rank: Superelite
Right, Part 1 has arrived todayBigGrin Now do i start a build diary or not (that is the question- to quote somebody famousLOL ) ?
Going to study all the bits, read instructions, and then re-read Tomicks build diary.....then GET BUILDING!!!!Love
CaptnBirdseye
#11 Posted : 09 April 2011 14:53:58
Rank: Superelite
Confused Ummm.Opened the packaging to find one of the compartments(?) has a piece missing. but for the life of me i cannot see what!!!
The right hand side compartment next to the hull frames is empty and looks to have been cut open. Should there have been a tube of adhesive or something?
If anyone can help solve this mystery, it would be greatly appreciated
Rgds
Graham
#12 Posted : 09 April 2011 16:52:27
No panic, no parts missing from the blister; a glue item was removed from the pack which was unsuitable for UK supply Wink
CaptnBirdseye
#13 Posted : 10 April 2011 13:05:15
Rank: Superelite
Thanks mateBigGrin
This page was generated in 0.386 seconds.
