You've made a great start. The only advise I can give is to let the drill piece work and dont put too much pressure on it when you drill the hole. I put 0.25mm fibers into my console, I did use a 0.30mm drill piece and mushroomed the ends first before feeding them through. By doing this they will feed through much easier and the fibers will not pull through when you mushroom the ends. I did a tutorial on the custom build if you want to take a look. Very fiddly process though. Good luck, I hope this will save you some drill pieces, and I look forward to seeing some pictures of them working soon. Regards Mark Regards Markwarren (Mark) Admin
 Rank: Pro Groups: Registered
Joined: 20/12/2016 Posts: 138 Points: 414 Location: Plant City, FL
Hyperdrive Kid wrote:Thanks for the advise, I was thinking of ordering some .30 drills, but can't wait for them to arrive, so I have tried using tiny sewing needles heated up on a bottle top..... mushroomed the end and it works perfectly... also the time it take to make the hole and thread it through is about 15 seconds...... I can fit hundreds if I want.....and my nerves will be fine.... There is always a shortcut !! like the other post, with drills and saws -- let the tool do the work! that is always true and even more so with the small tools. slow is steady steady is smooth smooth is fast like US Navy Seals....
I would love to see the video but that link doesn't take you to your customised falcon rather an advertisement for model space
No1crazyhorse wrote:I would love to see the video but that link doesn't take you to your customised falcon rather an advertisement for model space have a look at this link. http://forum.model-space....aspx?g=topics&f=315
