16 Pages «<1011121314>»
Eaglemoss Delorean Options
#221 Posted : 25 May 2017 16:54:36
Very impressive SpikeBigGrin looks greatBigGrin regards PhilCool
#222 Posted : 25 May 2017 19:20:25
Nice work on that engine Spike Cool looks great.
#223 Posted : 25 May 2017 21:46:28
Looking good Spike, the engine is really starting to take shape now Cool
spike
#224 Posted : 25 May 2017 22:02:04
Thanks guys for looking in BigGrin the engine is a nice size and loads of detailing, should look grand when its all finished.
Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
#225 Posted : 26 May 2017 18:09:44
Just a thought...
So far, all the engine/gearbox parts are the same silver colour.
I haven't looked or Googled, but would a few different silvers, gun metals, black etc add more interest and visual appeal?
Having said that, I'm very tempted to start on mine...
stevegbr
#226 Posted : 26 May 2017 18:22:02
roymattblack wrote:
Just a thought...
seen a couple of good ones on facebook, it makes a difference.
spike
#227 Posted : 20 July 2017 10:16:26
Sorry guys for taking this long to update the build. Had so much on Crying
But now i can get back to working on the build i am 9 issues behind so i will get them all put on today.
Issue 22
Parts -
Bracket
Cover
Arm
Throttle Control
Thermostat
Fuel Distributor
Fuel Injectors
Mixture Control Unit
Mixture Unit Housing and Throttle Valve Assembly
Intake Manifolds
13x AP Screws
1x MM Screw
Hoses (Short)
Hoses (Medium)
Hoses (Long)
spike attached the following image(s):
Thanks for looking.
Duane
spike
#228 Posted : 20 July 2017 10:26:28
Lower the cover onto the bracket then place the assembly onto the post on the front of the engine and fix in place with an MM screw.
Thanks for looking.
Duane
spike
#229 Posted : 20 July 2017 10:35:44
Fix the thermostat to the top of the engine at the rear and add 2 AP screws.
Thanks for looking.
Duane
spike
#230 Posted : 20 July 2017 10:47:50
Place the throttle control onto the arm and add an AP screw. Place the assembly onto the top of the engine and secure to the thermostat cover with an AP screw.
Thanks for looking.
Duane
spike
#231 Posted : 20 July 2017 11:11:04
Place the fuel distributor onto the square part on the mixture control unit, aligning the holes on both parts, then add 2 AP screws. Add the assembly onto the mixture unit housing and add an AP screw. Take the assembly and fit the intake manifolds onto the end and secure with 2 AP screws. Place the assembly between the air intakes on top of the engine and then secure with 4 AP screws.
Thanks for looking.
Duane
spike
#232 Posted : 20 July 2017 11:48:03
Insert the 6 fuel injectors into the holes in the top of the distributor facing left and right.
Thanks for looking.
Duane
spike
#233 Posted : 20 July 2017 12:21:11
Fit 1 end of a short hose onto the front right injector and the other end onto the first post on the right cylinder head. Fit the second short hose between the front left injector and the first post on the left cylinder head.
Fit a medium hose between the second right injector and the second post on the right cylinder head. Fit the second medium hose between the corresponding parts on the left side of the engine.
Fit a long hose between the last 2 points on the right of the distributor and the cylinder head. Fit the second long hose between the same points on the left side of the engine.
Thanks for looking.
Duane
#234 Posted : 20 July 2017 15:22:26
Great update SpikeBigGrin really look an impressive lumpDrool Drool regards PhilCool
spike
#235 Posted : 20 July 2017 16:17:25
Thanks for looking in Phil the details are fab i may go the extra mile with some more details on the engine.
Thanks for looking.
Duane
spike
#236 Posted : 20 July 2017 16:40:01
Issue 23
Parts -
Distributor Bracket
Distributor Rear
Distributor Front
Engine Side Bracket
Transmission Case Left Bracket
Transmission Case Right Bracket
Dipstick
3x AM Screws
4x DM Screws
3x AP Screws
Thanks for looking.
Duane
spike
#237 Posted : 20 July 2017 16:58:35
Place the engine side bracket up against the right side of the engine add secure with 2 AM screws. Combine the Distributor front and rear and fix them together with an AP screw. Place the alternator assembly on the right side of the engine below the engine bracket and secure with 2 AP screws
Thanks for looking.
Duane
spike
#238 Posted : 20 July 2017 17:14:29
Place the distributor bracket onto the rear of the engine and the alternator and fix in place with am AM screw.
Thanks for looking.
Duane
spike
#239 Posted : 20 July 2017 17:18:01
Pass the dipstick through the manifold and into the dipstick hole in the bottom of the engine.
Thanks for looking.
Duane
spike
#240 Posted : 20 July 2017 17:23:15
Secure the transmission case bracket to the left side of the transmission case and add 2 DM screws. Do the same on the right side of the transmission case.
Thanks for looking.
Duane
Guest (6)
This page was generated in 0.447 seconds.
