6 Pages 123>»
Delboy`s C57 Options
#1 Posted : 28 May 2017 14:14:13
Hi All,BigGrin
This will be my "early" morning bolt together build.(I work nights and it`s something I can do without disturbing anyone)
The diary will consist of end of stage pics only.
So watch this space.
#2 Posted : 28 May 2017 15:35:04
Derek
A bolt together can be a welcome change and quite satisfying because you can get to an end result easier in many cases.
Hope you enjoy. It looks a nice model and i thought the pre-painted finish a great added bonus.
I still have some of my d-51 to finish and its getting around to sorting the paint out that is holding me back on that one.
#3 Posted : 28 May 2017 19:16:30
BigGrin It really is a nice kit and the brass pipework certainly sets her offCool
Metal Mech
#4 Posted : 28 May 2017 19:25:19
This is one I would love to build one day. Never built a locomotive or a brass kit.
Looking forward to see your build progress.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
#5 Posted : 28 May 2017 22:43:48
Good luck with it Derek, I'll definitely be one of your followers....Cool Cool
#6 Posted : 29 May 2017 14:30:25
You will love this one Derek it's a really great build Cool
A word of advice if I may, when you are attaching the eyebolts to the boiler before securing them I would put one of the handrail bars through to make sure they are all aligned perfectly. If they're not perfectly aligned it will make it hard work getting them in later. Cool
#7 Posted : 29 May 2017 16:43:25
Thanks for the interest. Cool
Dave - thanks for the tip, I`m always up for tips/advise if it makes a job easier.Blink
#8 Posted : 29 May 2017 18:55:17
Hi look forward to your build of this its a great build. That's a good tip from dave. Just to add to it I drilled my handrail stantions out just to remove the paint in the hole.found that some but not all were tight for the rail. Which results in scraping the paint off the rail when you insert them.cheers mick. BigGrin BigGrin
#9 Posted : 30 May 2017 06:26:52
Well here we go. Got home just over an hour ago.
First, thanks for the second tip from Mick. Cool
Now this may not be an update of a full issue later on in the build, but this first one is nice and easy to get going.Laugh
Cut some wire. Ah, have a gadget for that to stop making bad shapes at the cut point. Cheers Jase, I see one of these in a build of yours.Blink
So cut the bits, fitted to number plate. Then using the spacer gauge fitted the number plate to the front cover.
That`s it Huh ,pics below and next update soon.
#10 Posted : 30 May 2017 08:02:45
So, next stage before I go to bed.
Fit the rear ring to the boiler.(Four screws)
Fit the front boiler door to the boiler.(Four screws)
Note: Be careful with the screws. Turn them in and then turn them back and carry on doing that until they seat properly.
Pics below.
#11 Posted : 30 May 2017 08:34:23
Nice start Derek, enjoy the build....Cool Cool
#12 Posted : 30 May 2017 12:52:17
Great start Derek, nice looking gadget as well BigGrin
#13 Posted : 30 May 2017 17:36:53
Thanks to those who looked in, much appreciated. CoolCool
Here`s a link to the wire guillotine and it`s worth a look around the proops site as they do lots of hobby stuff.
Proops Bros
#14 Posted : 30 May 2017 20:04:42
Really nice start Derek Cool
#15 Posted : 30 May 2017 20:30:38
BigGrin Nice start DerekCool
#16 Posted : 31 May 2017 07:36:36
I`m loving this build, Cool Cool , an hour in the morning just chills me out having got home from work.
Thanks to those looking in and for the kind comments. Love
So today, fit two rods to the double wheel assembly with bushes and screws.
Nice and gentle start.Laugh
Fit the two chimney parts together, steady with the glue here.Blink
Fit the chimney to the cylinder bit, you may have noticed that at this point my heads not round the technical terms. Flapper. Will get there I promise. Laugh
So now it`s the spark arrestor, (think that`s right, sure someone will tell me Blushing ), bit more fiddley but nothing to get too concerned about.
"Now" fit the spark arrestor to the bottom of the smoke stack, "DOH" it`s called a chimney.Confused
Don`t stick your finger to the inside of the smoke box. Blushing Not going to explain that one.
Add two pivots to the smoke box and a lever to the pivot on the right side. DONE BigGrin
So a few pics of progress so far:
#17 Posted : 31 May 2017 08:03:25
Nice start Derek, it looks a great build.BigGrin
#18 Posted : 31 May 2017 08:18:46
Lovely update Derek, looking good....Cool Cool
#19 Posted : 01 June 2017 19:05:45
Thanks to Mark and Alan for your comments. Cool
Got a bit too involved with other things this morning and had to sleep before putting this update together, but here it is:
Pics below show the Front deck base fitted.
The Feedwater Heater assembled.
The Feedwater Heater and its holder assembled and fitted.
The Feedwater Holder top plate fitted.
That`s it up to the end of stage 6.
#20 Posted : 01 June 2017 20:04:49
Steaming along with this Derek BigGrin nice work.
6 Pages 123>»
This page was generated in 0.256 seconds.
