12 Pages <12345>»
Pete's R2 build Options
Ritchie69
#41 Posted : 29 May 2017 16:09:41
Issue 19
This has to the most mind blowing issue so far. Confused
Only 2 leg details to insert.
Ritchie69 attached the following image(s):
Completed - R2D2
Ritchie69
#42 Posted : 29 May 2017 16:12:24
Issue 20
Only 1 dome frame to attach. The right leg sensor and ankle plate are for later.
Completed - R2D2
Ritchie69
#43 Posted : 29 May 2017 16:18:44
All in all this build is coming on nicely. So far the whole structure is very well built and the parts are not too flimsy. It is also getting quite heavy.
The build is a little slow just now, but hopping that it picks up soon with all the parts not being used building up. BigGrin
Peter
Completed - R2D2
Narayan
#44 Posted : 29 May 2017 16:46:56
Nice progress so far Peter.
Graham
#45 Posted : 29 May 2017 17:34:02
Nice job and you're right, it starting to get some weight about it.
#46 Posted : 29 May 2017 19:01:38
Looking good, well done....Cool Cool
#47 Posted : 29 May 2017 20:08:53
Looking good Peter, it's certainly taking shape.
MarkBigGrin
Spudtrooper37
#48 Posted : 30 May 2017 11:54:24
Nice to see some good progress.
Some issue's just don't make sense (I will be getting to that exciting issue soon) but I guess that how they drag it out over 2 years
Darren
Have an AWSOME day and may the Force be with you always 😉
Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger
- Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
Ritchie69
#49 Posted : 30 May 2017 20:45:48
Thanks all
I suppose your right Darren, it's there way of stretching out the issues for the 2 years BigGrin
Roll on when there is more than just about 20 minutes of build per month. It takes me longer to take the photos and post an update.
Peter
Completed - R2D2
Spudtrooper37
#50 Posted : 30 May 2017 23:05:57
If R2D2 does everything what deagostini says then 2 years and £900 will be worth it.
Everything time I look at R2D2 dome I get giddy 😀
Darren
Ritchie69
#51 Posted : 24 June 2017 18:54:14
Here we go with this months build.
Issue 21
Here we will be securing the leg support to the leg. Then adding the first part of the wheel support. The inside leg cover will be for later and more screws as well.
Completed - R2D2
Ritchie69
#52 Posted : 24 June 2017 18:57:04
Issue 22
Just putting together more lights for the dome.
Completed - R2D2
Ritchie69
#53 Posted : 24 June 2017 18:58:45
Issue 23
Only 1 part of the dome to attach. The rest is for later.
Completed - R2D2
Ritchie69
#54 Posted : 24 June 2017 19:00:16
Issue 24
Only the wheel to start putting together. And more screws for later.
Completed - R2D2
#55 Posted : 24 June 2017 21:16:03
Coming along nicely, starting to take shape.
#56 Posted : 24 June 2017 21:16:04
#57 Posted : 25 June 2017 09:02:25
Nice update, really taking shape now.
Ritchie69
#58 Posted : 26 July 2017 20:10:17
Finally got round to this months build, it's been a busy week. I became a grand dad for the first time. My daughter gave birth to lovely little boy.
So the build.
Issue 25
The last piece of the dome frame fitted. And a couple of parts of the support for fitting later.
Completed - R2D2
Ritchie69
#59 Posted : 26 July 2017 20:14:24
Issue 26
Attached the wheel frame/surround with bearing and slotting in the wheel.
Completed - R2D2
Ritchie69
#60 Posted : 26 July 2017 20:17:17
Issue 27
The start of the projector. Circuit board fitted, now having to wait until next months issue 29 to test it Crying
Completed - R2D2
12 Pages <12345>»
This page was generated in 1.322 seconds.
