13 Pages «<678910>»
Panart 1/16 Victory Sloop Build Options
#141 Posted : 30 May 2017 05:02:07
BigGrin Lovely work Alan Cool
#142 Posted : 30 May 2017 08:40:48
Thanks Martyn, onwards and upwards we go....Cool Cool
#143 Posted : 30 May 2017 12:49:19
Very nice work on the barrel Alan BigGrin
#144 Posted : 30 May 2017 20:37:59
BigGrin Very nice workCool
#145 Posted : 30 May 2017 21:35:42
Love the barrel, nice job.
#146 Posted : 30 May 2017 22:57:47
Thanks for looking in guys, appreciated....Cool Cool
#147 Posted : 30 May 2017 23:53:38
Very nice Alan, the barrel looks awesome. Very realistic...
Chris Cool
DaDokta
#148 Posted : 31 May 2017 06:16:04
I love that barrel!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
z8000783
#149 Posted : 31 May 2017 06:18:29
Groups: Unapproved
I appear to missed this one. Just beautiful, Alan.
#150 Posted : 31 May 2017 08:15:41
Thanks for the kind comments Chris, Walter and John appreciated....Cool Cool
#151 Posted : 31 May 2017 12:13:51
Hi Alan,
stunning looking build. very nice neat and tidy looking.
Ian Cool Cool BigGrin Drool Drool Drool
#152 Posted : 31 May 2017 12:46:04
#153 Posted : 31 May 2017 13:10:57
Love it look`s outstanding Alan Drool the bucket is brilliantBigGrin regards PhilCool
Sticky Wickett
#154 Posted : 31 May 2017 13:55:14
Fantastic work there Alan! Top job!
Phil W.
#155 Posted : 31 May 2017 22:46:11
Appreciate all who looked in and for your very kind comments....Cool Cool... more soon....
#156 Posted : 16 July 2017 00:20:41
Some more progress made on this one. Carried on working on some of the ancillary items starting with the hand axe, the shaft from this has been carved from 4mm dowel, completed axe then matt varnished.
Next on the list was to make up the supports for the mast, supports are used only when the mast is in the stowed position. Supports had to be drawn, cut and carved from 3.5 x 17mm Lime wood strip then varnished. The two base supports were made from 4x6mm lime wood with 4mm holes being drilled, starting with a 1mm drill bit and working up to 4mm. Also made up 4 x securing blocks to be fitted later.....Cool Cool
To make up the sail bag I cut a piece of old wooden curtain rail 30mm in diameter and wrapped it in cling film. Cut a piece of canvas and wrapped it round the rail and glued the seam using contact adhesive, the cling film prevented the canvas sticking to the rail... Folded over the ends and glued, once dried simply removed the rail and packed the bag with cut strips of material. Tied off the top to finish....Cool Cool
Last task on this build session was to make up the stern hatch covers and floor gratings. Gratings proved to be a long process due to the strips provided being too thick to fit into the cross pieces and required to be sanded down to fit. Once done, all given a fine sanding followed by 2 coats of matt varnish. The gratings are not yet glued in position, they are simply dry fitted for now.....Cool Cool
That's it for now, more to come soon, so until then happy building all....
jack.aubrey
#157 Posted : 16 July 2017 07:28:51
Very nice model, Alan.
Very nice . .
I made a similar model from Panart (Armed launch) and I well know the traps you have found with this build . .
Excellent job.
Jack.
#158 Posted : 16 July 2017 07:31:03
BigGrin Stunning job Alan Drool
#159 Posted : 16 July 2017 08:49:23
Thanks Guys, appreciated..
@Jack, she has her problems just as any kit does and it certainly not a kit for the beginner. That said though, she is an absolute joy to build.....Cool Cool .. Thanks again.....
#160 Posted : 16 July 2017 09:34:28
Your making a beautiful job of this Alan BigGrin
13 Pages «<678910>»
This page was generated in 0.372 seconds.
