Incorrect part detail Options
66Mustang
#1 Posted : 30 May 2017 19:36:43
Rank: Beginner Level 1
I notice that on part 75 the distributor cap HT or spark plug leads are incorrect for the proper firing order of the engine. Has anybody else noticed this? With all the great detail on this car I am surprised they have done that. Confused
#2 Posted : 30 May 2017 20:10:16
I am not quite sure what you, but then I am no engine guy. Could you post a picture to show what you are referring to
66Mustang
#3 Posted : 30 May 2017 20:48:39
The distributor leads turns counter clockwise firing on cylinder 1 which is the first cylinder on the left as you look at the engine from the front. The leads are symetrical from the top to each side which suggests the firing order is 4-3-2-1-5-6-7-8, the correct firing order is 1-5-4-2-6-3-7-8. The configuration you have the engine would not run. The leads would cross over the top of the distributor cap and not come out evenly around the sides of the distributor cap which looks neat and tidy.
66Mustang attached the following image(s):
#4 Posted : 31 May 2017 20:09:55
It took quite some head scratching to get my head around this even after you posted the picture. The majority of people would not even have noticed.
Unfortunately as detailed as models are these days you would be hard pressed to find any model 100% accurate hence why there is a industry dedicated to super detailing models.
StevieDisco
#5 Posted : 11 July 2017 17:13:42
I noticed the incorrect firing order as soon as I saw the build photos for that issue. I assumed the design team that worked on the engine got lazy and figured nobody would notice. I was going to ask if anyone had tried wiring in the correct order and if the plug wires were long enough. If not then I would have to do some minor reworking.
On the subject of the engine...Can someone tell me what a 'gas recycling filter' is? (Issue #72). It shows mounted where the starter should normally be and it looks sorta similar to a starter.
StevieDisco attached the following image(s):
"A picture is worth a thousand words but a model is worth a thousand pictures" - Harley J. Earl
#6 Posted : 13 July 2017 00:07:02
I would say that it is the fuel (gas) filter
70 Coupe
#7 Posted : 13 July 2017 21:59:12
The gas recycling filter was a part of the emissions (smog) control equipment, there was one fitted to my 1:1 70 Coupe, (which was long since ditched as it cuts down on performance) although it wasn't mounted to the engine block, the one on the model is a bit of a mystery.....Confused
Hope this helps.....
Tony
StevieDisco
#8 Posted : 14 July 2017 14:47:00
Thanks guys. I'm going to either scratch-build a starter or kit-bash one from one of the Lindberg kits (Ford Y-block) and mount it where the gas recycling filter goes. Since I'm already adding a starter relay then having a starter only makes sense.
rpmracing18
#9 Posted : 14 August 2017 04:58:28
I noticed also there is no solenoid switch, no voltage regulator and no battery cable wires.
StevieDisco
#10 Posted : 14 August 2017 16:10:03
I made my own and will also be adding the VR and battery cables.
StevieDisco
#11 Posted : 14 August 2017 16:11:47
rpmracing18
#12 Posted : 14 August 2017 21:04:13
Wow, Cool!! Where can I find these items? Especiaaly the VR and solenoid? what are you going to use for cables?
Rich
StevieDisco
#13 Posted : 15 August 2017 12:54:14
Rich
Take a look at Post #10 in my Shelby Modifications. I made the starter relay from Evergreen tube and sheet. Hardware was 0-80 and 00-90.
Cable will be wire insulation (stripped away from the wire) with either a small eye-pin or rod-end inserted on the ends. See Post #37 to see the eye-pin version.
I haven't made the VR yet but it should be much easier due to it's simplified shape.
rpmracing18
#14 Posted : 18 August 2017 01:22:39
Ok, The detail over on your shelby mod thread is simply amazing!!! I just don't have the patience to do any kind of extensive mods like that, I'm too old and my nerves and eyesight isn't there. Your skill is awesome!!!
If you were in the US, I'd pay you to build me a soleniod switch and a voltage regulator!!!!!
Thanks for sharing, can't wait to see your other detail workBigGrin
This page was generated in 0.066 seconds.
