106 Pages «<3536373839>»
Sticky Wickett
#721 Posted : 31 May 2017 22:42:12
All templates fitted.
Sticky Wickett
#722 Posted : 31 May 2017 22:47:39
I then had to remove sections of it to accommodate the vertical mdf supports. The cuts were rough but at this stage i just wanted to gauge how it looked and work out how i was going to strengthen and support it. Confused
The attached photos show were i had cut.
Sticky Wickett
#723 Posted : 31 May 2017 22:54:27
Once i had the shell sitting about right within the torpedo compartment, i marked it's edge onto the inside of the planked hull. I proceeded to glue in plastic strip along that mark so that the edge of the shell had something to butt up against.
The attached photo shows the strips being fitted.
Sticky Wickett
#724 Posted : 31 May 2017 22:56:22
This photo shows the shell being test fitted with it's edges butted up against the strips.
Sticky Wickett
#725 Posted : 31 May 2017 22:57:54
Test fitting the shell.
Sticky Wickett
#726 Posted : 31 May 2017 22:58:49
Another angle showing the shell and support strips.
Sticky Wickett
#727 Posted : 31 May 2017 23:02:20
The next part was to fix strip at right angles to the existing edge pieces. By doing this the edge of the shell is fixed against a solid support.
Sticky Wickett
#728 Posted : 31 May 2017 23:04:14
First edge support completed.
Sticky Wickett
#729 Posted : 31 May 2017 23:07:16
By using the other half of the semi-circular templates, i could butt them up against the supports and begin to gauge the shape and size of the supports to fit underneath the shell.
This photo shows No.1 template being positioned.
Sticky Wickett
#730 Posted : 31 May 2017 23:12:11
This photo shows one of the supports to fit under the shell where No.1 template is positioned. This piece, although simple looking, took nearly an hour to make. I had to continuously offer it up against the template to obtain the correct profile, while both were free floating and not fixed. Very time consuming!
Sticky Wickett
#731 Posted : 31 May 2017 23:13:41
This photo shows the curved support and semi-circular template positioned in place
Sticky Wickett
#732 Posted : 31 May 2017 23:15:41
I then glued the curved support in place.
Sticky Wickett
#733 Posted : 31 May 2017 23:19:34
I used the same method to make the opposite side. Again, another hour!Blink
Sticky Wickett
#734 Posted : 31 May 2017 23:22:07
Template being checked for fit.
Sticky Wickett
#735 Posted : 31 May 2017 23:25:42
Once happy, i proceeded in the same sequence for No.4 template, the extra edging strip and curved supports.
This photo shows the extra strip fitted.
Sticky Wickett
#736 Posted : 31 May 2017 23:28:15
Another angle showing the work so far.
Sticky Wickett
#737 Posted : 31 May 2017 23:29:20
No.4 template being checked for fit against the curved supports.
Sticky Wickett
#738 Posted : 31 May 2017 23:30:22
No.4 curved support fitted.
Sticky Wickett
#739 Posted : 31 May 2017 23:31:47
This photo shows No.4 template being compared to the curved supports.
Sticky Wickett
#740 Posted : 31 May 2017 23:32:43
Supports in place.
Guest (18)
This page was generated in 0.764 seconds.
