51 Pages «<1617181920>»
DaDokta`s Build Options
DaDokta
#341 Posted : 02 June 2017 13:04:29
Thanks guys!
All the decks are planked now!
As you can see i also re-planked the bow-deck with the 4mm Planks to achieve a uniform look!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Foz
#342 Posted : 02 June 2017 13:20:55
A stunning build Walter, really nice detail and look forward to seeing your progress
Foz
#343 Posted : 02 June 2017 13:52:55
Hi Walter.
Looking fantastic. look forward to your next update.
Ian Cool BigGrin
NikonD60
#344 Posted : 03 June 2017 14:29:16
Lovely job with the deck planking Walter. Your 4mm planks certainly look the job.
Today is the tomorrow you wished for yesterday!
Garth
#345 Posted : 03 June 2017 17:07:30
Hi Walter,
Your decks are looking fantastic. Looking forward to your next update.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
DaDokta
#346 Posted : 06 June 2017 08:01:09
Thanks guys!
I tried to build the canvas (don`t know the exact purpose of this) hanging from the roof off the poop deck (oh god my english!).
I used some kitchen towel soaked in diluted wood glue and some fine thread.
This was then mounted to the front strip of the poop deck and all glued in place.
There will be a bigger update in the next few days - as i`m busy with the bulwarks of the poop - which again i will not exactly build as recommended! :)
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#347 Posted : 06 June 2017 08:27:14
Some more nice touches Walter. It's amazing what can be done using some everyday household materials found around the home..... Cool Cool .. Coming along a treat.....Cool Cool
#348 Posted : 06 June 2017 08:36:09
BigGrin Lovely work Walter she is coming along a treat Cool
Foz
#349 Posted : 06 June 2017 19:05:38
Very nice indeed Walter. Love the detail you are doing on her and look forward to your progress
Foz
#350 Posted : 06 June 2017 22:27:23
Great work Walter, nice detail.
NikonD60
#351 Posted : 07 June 2017 01:14:20
Nice work Walter. Some great Ideas.
Alan.
Garth
#352 Posted : 07 June 2017 05:46:37
Nice work Walter.
Love your attention to detail.
Kind regards,
Garth
DaDokta
#353 Posted : 07 June 2017 08:30:43
Thanks guys!
So next step were the bulwarks of the poop deck. Looking into McKay`s book i realized, that the real bulwarks look quite differently than the way the instructions tell us to build them.
As you can see the bulwarks run in a slight curve and meet the level of the poop-deck aproximately at the front end of the light-house. There is a much smaller curve down to the bulwarks of the main deck which reach much further back - right to the back-end of the third gun-port.
Of course i couldn`t help but try to achieve this as closely as possible.
I built up the additional planks (just the outer ones!) and marked where to cut. As you can see i wouldn`t have needed the second plank.
Then i slowly and carefully carved my way to the right shape.
I glued some 3x3mm pieces to the inside of the outer bulwark
Then i built up the inner bulwark.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#354 Posted : 07 June 2017 08:38:01
BigGrin Brilliant attention to detail Walter lovely work Cool
#355 Posted : 07 June 2017 23:12:25
Very nice work as usual Walter, very well done.....Cool Cool
NikonD60
#356 Posted : 08 June 2017 11:39:17
Well done Walter. It's good that you are following the original design.
Alan.
#357 Posted : 08 June 2017 15:17:25
Fabulous work as always Walter BigGrin
#358 Posted : 08 June 2017 18:38:04
Walter
Looks fantastic and a lot of skill you have with these alterations you are making.
Foz
#359 Posted : 08 June 2017 19:46:53
Fantastic work Walter, cant wait to see more of your build ThumpUp
Foz
#360 Posted : 08 June 2017 20:59:07
BigGrin Looking good WalterCool
Guest (23)
This page was generated in 0.252 seconds.
