10 Pages «<45678>»
NikonD60 Options
darkwoodster
#101 Posted : 22 May 2017 20:56:58
Nice work. Its also impressive how well you are doing with the limited function in your hands.
As for the last 10 planks. Mine worked out similar. So rather then been left with 0.5mm gap at the end. I would divide the 45.5 by 10 planks for a nice fit. Also because its nice have a little left to play with than a little under if you've over sanded any.
Neil
PS, I am a little infront of you, but you are catching me up fast!
DaDokta
#102 Posted : 23 May 2017 08:14:54
Hi Alan! The planking looks spot-on so far - a fair amount of filler and she will look perfect once sanded down!
Keep up the good work!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#103 Posted : 23 May 2017 12:37:46
Almost done with the planking BigGrin looking good.
NikonD60
#104 Posted : 23 May 2017 14:25:37
Thanks for your comments and advice.
Neil, I will take your advice and work off the the 45½mm. I did not consider over sanding when thinking about it. The ½mm could easily grow to a large gap.
Tanks again,
Today is the tomorrow you wished for yesterday!
Garth
#105 Posted : 25 May 2017 12:19:36
Hi Alan,
Your planking is coming along nicely. Good luck with the last bit. Well done.
Hope your hands are on the mend.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
NikonD60
#106 Posted : 03 June 2017 15:11:27
Closed up the starboard side. I'm quite pleased with it although some filler will be needed (photos 1-4).
Now to start on the port side.
I've bought the copper tiles for the hull so I'm not too concerned about how it looks as long as it's smooth.
NikonD60 attached the following image(s):
#107 Posted : 03 June 2017 15:26:05
Looks very good.
Lots of involved work to get it to this stage so very well done to you.
z8000783
#108 Posted : 03 June 2017 15:30:33
Groups: Unapproved
Looks good Alan. Don't worry about the filler if you're tiling it though.
Foz
#109 Posted : 03 June 2017 17:27:38
Hi there
Your build is comming along very nicely, keep up the good work.
Foz BigGrin
#110 Posted : 03 June 2017 23:18:55
Its a major achievement getting the hull completely planked and your almost there Alan so well done to you....Cool Cool .. She's coming along and looks as if she'll sand down very nicely....Cool Cool .. Look forward to seeing your next update.....Cool Cool
darkwoodster
#111 Posted : 04 June 2017 10:44:07
Hi Alan,
She's looking good. Those last 10 planks are like been on a long distance run and seeing the finish line in sight. You find a chunk of energy to push you across that finish line.
Neil
Garth
#112 Posted : 04 June 2017 14:34:27
Hi Alan,
Nice update. Your planking is looking good.
You're almost there.
Kind regards,
Garth
#113 Posted : 04 June 2017 18:54:03
Great job on the planking, always a sense of achievement when the last plank goes in.
NikonD60
#114 Posted : 05 June 2017 01:00:01
Thanks for looking in and all your kind comments.
DaDokta
#115 Posted : 06 June 2017 07:51:38
Hi Alan - the planking is looking good! Don`t worry about the filler unless you go for the unpainted version!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
NikonD60
#116 Posted : 07 June 2017 01:06:13
AT LAST - FINISHED PLANKING THE HULL!
Getting there.
Finally fitted the last plank (photos 1-4).
I was concentrating so hard on getting the last planks fitted, I never considered turning it over and shaking the dropped pins and cuttings out.
When I put it on the stand I discovered that I was the owner of the largest maraca in North Tyneside! Had to ease the garboard plank back to shake it all out (photos 5-7).
Time to start sanding. might be a while.
Alan.
Garth
#117 Posted : 07 June 2017 05:50:13
Hi Alan,
Congratulations on the planking - it's really another milestone in the build. She's really starting to take shape now.
Kind regards,
Garth
DaDokta
#118 Posted : 07 June 2017 06:09:45
Congratulations! And now much fun with the sanding - i find it very satisfying to see the real shape come out during that process!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#119 Posted : 07 June 2017 06:32:37
BigGrin Very nicely done its very satisfying closing up the hull Cool . Happy sanding BigGrin
z8000783
#120 Posted : 07 June 2017 06:45:06
Groups: Unapproved
Nice work Alan, and you'll be even more impressed once she's sanded down.
10 Pages «<45678>»
