plannking iron Options
ronald305
#1 Posted : 06 June 2017 01:44:31
hello there
does anyone know how to us the planking iron and the 4 wood curves that comes with it, and how to keep them steady in order to the iron also how long to soak the planks before bending thank you
Ronald
#2 Posted : 06 June 2017 08:04:49
Hi Ron
You may find this link useful.
https://www.youtube.com/watch?v=O8CoV8fkYTI
I soak the planks for around 10 mins in hot water and it tends to be sufficient in most cases, sometimes I will soak for longer depending on how tight a curve I need.
To keep the profiling block steady place the block in a vice...
Hope this helps..
ronald305
#3 Posted : 06 June 2017 19:12:20
yes I should thanks Alan
Ronnie
ronald305
#4 Posted : 06 June 2017 21:39:41
sorry I meant that should work thanks Alan
Ronald
ronald305
#5 Posted : 09 June 2017 21:28:11
Hi Alan
I watched the video is ok and interesting but it would have been much better if
the video had sound or the man explaining his method
Ronald
This page was generated in 1.647 seconds.
