WRIGGLES Options
Glen
#1 Posted : 30 March 2011 13:37:10
Hi all,
I'm a little confussed about the wriggles over the gunports, we were given two metal wriggles do we get more of these or do we have to use them as a template, if so what wood do we use to cut them out off?Confused Glen
Roger the Cabin Boy
Tarbrush
#2 Posted : 30 March 2011 13:46:02
Hi Glen,
I hope the wriggles are templates. Others will be supplied in due course.
Fear not it will all be revealed in the end!Bored
Laury
Glen
#3 Posted : 30 March 2011 13:47:26
Thanks Tarbrush, Thank the Lord for that.
Roger the Cabin Boy
#4 Posted : 30 March 2011 14:24:53
It does say the two sample wriggles are to be used as templates to cut the shapes, the balance will be supplied at a later date, in the meantime keep the two you have safe.
#5 Posted : 30 March 2011 15:59:16
also the instruction show where to remove wood from.are marked with yellow and white dots.just in case you missed it.Mellow
This page was generated in 0.230 seconds.
