15 Pages «<1112131415>
Fozys Build Options
z8000783
#241 Posted : 10 June 2017 07:20:58
Groups: Unapproved
Mast looks great, Foz.
Foz
#242 Posted : 10 June 2017 20:58:54
Hi Folks
Just a quick question, i think i know the anser but i am just double checking.
I have decided not to put the sails on the Vic.
Now it says in the magazine that the blocks indicated by a star on the plans must be fitted.
Am i right in thinking that those with stars on are the only ones i need to add, and can leave all the rest off.
Foz
z8000783
#243 Posted : 10 June 2017 21:05:29
Groups: Unapproved
I thought it said - 'Need not be fitted'.
#244 Posted : 10 June 2017 23:00:06
Foz wrote:
Hi Folks
Foz
Hi Foz, the answer to your question lies in this post....
http://forum.model-space...aspx?g=posts&t=2403
Foz
#245 Posted : 11 June 2017 07:52:12
Hiya Alan
Yes have read that mate, i was just double checking that i read it right thats all
Thanks
Foz
#246 Posted : 11 June 2017 08:24:11
Foz wrote:
Hiya Alan
Thanks
Foz
No problem Foz, just wasn't sure if you'd seen it or not....Cool Cool .. For me, without sails is the way to go so you can see all that amazing detail on the decks and masts....Cool Cool .. Look forward to seeing her progress....Cool Cool
Foz
#247 Posted : 12 June 2017 11:07:57
Well not a lot to show this time, just the main spar but sharing it anyway.
Thats it for now.
Onto painting the hull next so i might get a bit messy lol
Happy building folks
Foz BigGrin
#248 Posted : 12 June 2017 12:18:35
Hi Foz.
Look forward to seeing your painting. It starts to look like the victory when her stripes go on. Ian BigGrin
Garth
#249 Posted : 13 June 2017 06:27:36
Hi Foz,
Masts are coming along nicely. Looking good.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
DaDokta
#250 Posted : 13 June 2017 10:33:28
The main spar looks great! Those wires for the foot-ropes look hard to attach?
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Foz
#251 Posted : 17 June 2017 17:12:02
Hiya Folks
Fiest off thanks for the great comments as always they are much appreciated.
Anyway, quick question for those that have painted there hull.
I have done some samples on spare timbers using the copper paint supplied and not really that happy with it but could put up with it if needed. Anyway, i see that revel do a metalic copper in there paints, has anyone used this and does it make much difference if it is used instead of the supplied paint.
Foz
#252 Posted : 17 June 2017 17:45:44
Foz wrote:
Hiya Folks
Foz
Foz
Great job on the spar - very neat piece of work.
If you are hand painting the metallic colours its always best to apply in thinned down layers rather than trying to get the required finish in one hit. A quick rub over with very fine wire wool can help between layers.
Over such a large area your very best option would be to spray the finish as it will go on a lot smoother and (espevially with the weather today) you wil not have the issues with the paint starting to dry on you before you have really got a nice smooth finish if handbrushing.
Foz
#253 Posted : 17 June 2017 17:50:11
Thanks for the advice Tony.
Will have a look for a copper spray as did not think about that.
I also thought that if i did use a metalic paint, then a clear matt varnish over the top may dull it down a bit.
Well have time to decide what to do
Foz
Foz
#254 Posted : 21 June 2017 09:45:02
Hiya Folks
Well finally got some paint on the hull so things starting to take shape now.
Here is progress so far.
Not happy with my straight waterline so a bit more work on that and also need to paint the hinges on the rudder black.
BUt its getting there slowly.
Any comments are always welcome.
Foz
DaDokta
#255 Posted : 21 June 2017 12:35:52
Hi Foz!
Did you use masking tape for your paint job?
I highly recommend Tamiya masking tape. Firmly apply it in a straight line.
I always apply one coat of the colour i am masking off along the tape which seals the tape so that the actual colour you want to paint with can`t run under the tape ( in your case - run the tape along the line on the black side - then paint black along the tape on the copper side - then paint your hull with the copper paint).
Let it dry and carefully remove the tape - and you have a perfect straight line without much effort.
Keep up the good work!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Foz
#256 Posted : 21 June 2017 12:48:17
Hiya Walter
Yes mate, i did use masking tape but not good enough as there was a bit seeped through.
I made it worse by trying to touch it up by free had which i should not have done with these shaky hands lol
Going to mask it off again and see what happens then.
Foz
Foz
#257 Posted : 25 June 2017 08:41:36
Hi Folks
SOme advice please
I have re-painted the hull on the Vic and it looks better than before but i would like to protect it more then just with the paint.
I tried a clear matt varnish, cheap one from wilko's but it started taking the paint off instead of protecting it.
Once again i repainted but dont want the same to happen again.
Is there anything i can use that will not strip the paint off as i do not want to repaint it yet again.
Oh and in the end i used the admiralty paints that was supplied.
Foz BigGrin
DaDokta
#258 Posted : 25 June 2017 12:11:13
Hi Foz,
i always use Tamiya TS-79 Semi gloss clear varnish spray.
Dont put on too much at once. First just a light misty coat - let it dry - then you can put on a little bit more and so on.
Never had a problem so far.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Garth
#259 Posted : 25 June 2017 15:35:28
Hi Foz,
Sorry to hear about your dilemma. No sound advice from my side as the products in South Africa will differ from yours.
My only suggestion is to do tests on off-cut material to test the compatibility of the various paints & thinner.
Good luck.
Kind regards,
Garth
Foz
#260 Posted : 26 June 2017 19:49:50
thanks Guys
Have ordered somew of that sprey you sugested Walter, will give it a try.
Foz
This page was generated in 1.675 seconds.
