106 Pages «<4142434445>»
#841 Posted : 15 June 2017 21:14:51
Great update Phil, the detail is looking the biz.....Drool Drool
Sticky Wickett
#842 Posted : 15 June 2017 21:40:41
Cool Thank you Alan. It's slowly coming together!
Phil W.
#843 Posted : 15 June 2017 22:18:11
Excellent as usual Phil, it's great seeing her come together.Drool
Sticky Wickett
#844 Posted : 15 June 2017 23:11:40
Cool
Thank you Mark.Cool Getting ever closer to the paint stage!BigGrin
Phil W.
#845 Posted : 16 June 2017 12:05:49
Hi Phil.
nice update on the rear bulkhead. looking great.
Ian Cool BigGrin
#846 Posted : 16 June 2017 15:51:47
Sticky Wickett
#847 Posted : 16 June 2017 18:01:52
ian smith wrote:
Hi Phil.
Ian Cool BigGrin
Cool Thanks very much Ian.BigGrin
Phil W.
Sticky Wickett
#848 Posted : 16 June 2017 18:03:29
stevie_o wrote:
Fantastic work Phil, and some lovely modsBigGrin really looking forward to seeing one of these finished!
Cool Thanks Steve. I'm looking at a Sep 2018 completion date, so stay tuned for further developments.
Kind Regards,
Phil W.
Sticky Wickett
#849 Posted : 22 June 2017 20:51:24
Good Evening from 'The Dockyard'.
This weeks update of my U230 U-boat build will be making the inner pressure hull and fitting the torpedo loading hatch.
The first job was to mark out where the torpedo loading hatch would be located. The attached photo shows the area to be removed.
Sticky Wickett
#850 Posted : 22 June 2017 20:52:49
This photo shows the cut -away area ready for test fitting the torpedo loading hatch.
Sticky Wickett
#851 Posted : 22 June 2017 20:53:57
Torpedo loading hatch being test fitted.
Sticky Wickett
#852 Posted : 22 June 2017 21:00:08
Once I was relatively happy with the fit of the hatch I removed it and started to then concentrate on the inner pressure hull. In a previous post i fitted the inner pressure but that was only made from 0.25mm thick plastic sheet and thus too thin on it's own. Rather than initially try to wrestle a thicker piece into place, it's easier to work a thinner sheet as it's more manipulative.
The second skin is 0.5mm thick plastic sheet. For it to locate at the rear bulkhead and follow the curve of the inner hull, i fixed a datum piece in place made from 2.0mm square strip. The attached photo shows the strip glued in.
Sticky Wickett
#853 Posted : 22 June 2017 21:04:34
Next up was to level off the edging where the hull meets the brass sheet. This was previously angled and i wanted to level it off to match the look of all the other compartments.
I carefully roughed it out with a dremel fitted with an angled grinding stone before filing to suit.
The attached photo shows the edging being roughed out.
Sticky Wickett
#854 Posted : 22 June 2017 21:05:35
Removing the majority with a dremel.
Sticky Wickett
#855 Posted : 22 June 2017 21:07:19
Filing to suit.
Sticky Wickett
#856 Posted : 22 June 2017 21:13:45
The next job was to make the inner hull from 0.5mm sheet. I decided to split the hull into two sections to make it easier to fit. The front section being the longer one while the back section incorporates the cut -out for the torpedo loading hatch.
The front section took several attempts as i had to make several cuts so that it sat correctly. If too much is removed, which is easy when there are no measurements to reference, i used it as a template and removed less from the next one. I think it was my third attempt when i got the hull template to sit correctly.
The attached photo shows the hull before fitting.
Sticky Wickett
#857 Posted : 22 June 2017 21:14:47
Inner pressure hull fitted.
Sticky Wickett
#858 Posted : 22 June 2017 21:15:23
Looking forward.
Sticky Wickett
#859 Posted : 22 June 2017 21:16:29
Looking aft.
Sticky Wickett
#860 Posted : 22 June 2017 21:22:43
The next job was to fit support pieces for the rear inner pressure hull. This section also includes the cut-out for the torpedo loading hatch.
This section proved to be problematic trying to gauge the depth of the supports. I spent many a head scratching moment and lots of trial and error before i was satisfied.Confused [blink
This photo shows some of the supports in place.
This page was generated in 0.404 seconds.
