Great update Phil, the detail is looking the biz..... Regards Alan
Gandale wrote:Great update Phil, the detail is looking the biz..... Regards Alan  Thank you Alan. It's slowly coming together! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,280 Points: 22,147 Location: Northamptonshire, England
Excellent as usual Phil, it's great seeing her come together. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Excellent as usual Phil, it's great seeing her come together. Mark Thank you Mark.  Getting ever closer to the paint stage! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hi Phil. nice update on the rear bulkhead. looking great. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Fantastic work Phil, and some lovely mods  really looking forward to seeing one of these finished! Steve
ian smith wrote:Hi Phil. nice update on the rear bulkhead. looking great. Ian  Thanks very much Ian. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
stevie_o wrote:Fantastic work Phil, and some lovely mods  really looking forward to seeing one of these finished! Steve  Thanks Steve. I'm looking at a Sep 2018 completion date, so stay tuned for further developments. Kind Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good Evening from 'The Dockyard'. This weeks update of my U230 U-boat build will be making the inner pressure hull and fitting the torpedo loading hatch. The first job was to mark out where the torpedo loading hatch would be located. The attached photo shows the area to be removed. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
This photo shows the cut -away area ready for test fitting the torpedo loading hatch. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Torpedo loading hatch being test fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Once I was relatively happy with the fit of the hatch I removed it and started to then concentrate on the inner pressure hull. In a previous post i fitted the inner pressure but that was only made from 0.25mm thick plastic sheet and thus too thin on it's own. Rather than initially try to wrestle a thicker piece into place, it's easier to work a thinner sheet as it's more manipulative. The second skin is 0.5mm thick plastic sheet. For it to locate at the rear bulkhead and follow the curve of the inner hull, i fixed a datum piece in place made from 2.0mm square strip. The attached photo shows the strip glued in. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Next up was to level off the edging where the hull meets the brass sheet. This was previously angled and i wanted to level it off to match the look of all the other compartments. I carefully roughed it out with a dremel fitted with an angled grinding stone before filing to suit. The attached photo shows the edging being roughed out. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Removing the majority with a dremel. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Filing to suit. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The next job was to make the inner hull from 0.5mm sheet. I decided to split the hull into two sections to make it easier to fit. The front section being the longer one while the back section incorporates the cut -out for the torpedo loading hatch. The front section took several attempts as i had to make several cuts so that it sat correctly. If too much is removed, which is easy when there are no measurements to reference, i used it as a template and removed less from the next one. I think it was my third attempt when i got the hull template to sit correctly. The attached photo shows the hull before fitting. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Inner pressure hull fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looking forward. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looking aft. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The next job was to fit support pieces for the rear inner pressure hull. This section also includes the cut-out for the torpedo loading hatch. This section proved to be problematic trying to gauge the depth of the supports. I spent many a head scratching moment and lots of trial and error before i was satisfied.  [blink This photo shows some of the supports in place. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (9)
